Pinout Color Codes / Tables
  • Pinout Color Codes / Tables
    I found this site, dunno if its been posted before. but useful for finding out what all the wires mean!
    http://www.pccables.com/cabtech.htm
    for the lazy:
    Serial Adapters
    DB-9 to DB-25 Adapter or Cable
    Used to adapt serial ports to the proper size
    25 Pin 9 Pin Signal-RS232
    Connector Connector
    1 n/a Protective Ground
    2 3 TX Transmit
    3 2 RX Recieve
    4 7 RTS Request to Send
    5 8 CTS Clear to Send
    6 6 DSR Data set Ready
    7 5 Signal Ground
    8 1 DCD Data carrier detect
    9 n/a + Transmit
    11 n/a - Transmit
    18 n/a + Recieve
    20 4 DTR Data terminal ready
    22 9 RI Ring Indicator
    23 n/a DSRD Data signal-rate indicator
    25 n/a - Recieve
    Opposite of Above
    TEST Adapters
    Serial Port Loopback (9 Pin)
    Used to verify that a port is working.
    9 PIN D-SUB FEMALE
    Name Pin Pin Name
    DCD 1 6 DSR
    DCD 1 9 RI
    RXD 2 3 TXD
    DTR 4 6 DSR
    RTS 7 8 CTS
    Serial Port Loopback (25 Pin)
    25 PIN D-SUB FEMALE
    Name Pin Pin
    1 7
    2 3
    4 5,8
    6 11,20,22
    15 17,23
    18 25
    Parallel Port Loopback (IBM, Checkit and Most Others)
    Used to verify that a Printer port is working.
    Name Pin Pin Name
    Strobe 1 13 Select
    Data Bit0 2 15 Error
    Acknowledge 10 16 Input Prime
    Busy 11 17 Select In
    Paper Out 12 14 Auto Feed XT
    Parallel Port Loopback (Norton)
    Used to verify that a port is working. Norton Utilities: Norton Diagnostics
    Name Pin Pin Name
    Data Bit 0 2 15 Error
    Data Bit 1 3 13 Select
    Data Bit 2 4 12 Paper Out
    Data Bit 3 5 10 Acknowledge
    Data Bit 4 6 11 Busy
    Power Cables
    Power Supply to Motherboard AT P8-P9
    Pin# Color Function
    1 Orange Power Good
    2 Red +5V DC
    3 Yellow +12V DC
    4 Blue -12V DC
    5 Black Ground
    6 Black Ground
    7 Black Ground
    8 Black Ground
    9 White -5V DC
    10 Red +5V DC
    11 Red +5V DC
    12 Red +5V DC
    Power Supply to Motherboard ATX
    Pin# Color Function
    1 Orange +3.3V DC
    2 Orange +3.3V DC
    3 Black Ground
    4 Red +5V DC
    5 Black Ground
    6 Red +5V DC
    7 Black Ground
    8 Gray Power OK
    9 Purple +5V standby
    10 Yellow +12V DC
    (11) Orange(22) +3.3V DC
    (11) Brown(22) 3.3V sense
    12 Blue -12V DC
    13 Black Ground
    14 Green PS-ON
    15 Black Ground
    16 Black Ground
    17 Black Ground
    18 White -5V DC
    19 Red +5V DC
    20 Red +5V DC
    Power Supply plug 5.25-inch 4-pin Molex
    Pin# Color Function
    1 Yellow +12V DC
    2 Black Ground
    3 Black Ground
    4 Red +5V DC
    Power supply plug 3.5-inch
    Pin# Color Function
    1 Yellow +12V DC
    2 Black Ground
    3 Black Ground
    4 Red +5V DC
    Monitor Reference
    Hercules/Monochrome Adapter
    Pin# Label Function
    1 GND Ground
    2 GND Ground
    3 N.C. Not Connected
    4 N.C. Not Connected
    5 N.C. Not Connected
    6 INTENSITY Intensity
    7 VIDEO TTL video signal
    8 H-SYNC Horizontal Synch (18.432KHz)
    9 V-SYNC Vertical Synch (50Hz)
    CGA Color Graphics Display Adapter
    Pin# Label Function
    1 GND Ground
    2 GND Ground
    3 RED Red color signal
    4 GREEN Green color signal
    5 BLUE Blue color signal
    6 INTENSITY + Intensity
    7 RES Reserved
    CGA Composite Video Used on Commodore systems old Apples
    Pin# Label Function
    1(pin) 1.5 Volt Dc Video Signal
    2(shell) GND Ground
    EGA Enhanced Graphics Adapter
    Pin# Label Function
    1 GND Ground
    2 RED2 Secondary Red color signal
    6 GREEN2 Secondary Green color signal + Intensity
    7 BLUE2 Secondary Blue color signal + Monochrome
    Color VGA Adapter
    Pin# Label Function
    1 RED Red color signal
    2 GREEN Green color signal
    3 BLUE Blue color signal
    4 ID2 Monitor identification bit 2
    6 GND-RED Ground Red signal
    7 GND-GREEN Ground Green signal
    8 GND-BLUE Ground Blue signal
    9 N.C. Not Connected
    10 GND-SYNC Ground Sync signal
    11 ID1 Monitor identification bit 1
    12 ID0 Monitor identification bit 0
    13 H-SYNC Horizontal Synchronization
    14 V-SYNC Vertical Synchronization
    15 N.C. Not connected
    Ribbon Cables
    EIDE IDE 40 Pin Cable
    Pin# Signal Description Function
    1 RESET Reset
    2 GND Ground
    3 DD7 Data Line 7
    4 DD8 Data Line 8
    5 DD6 Data Line 6
    6 DD9 Data Line 9
    7 DD5 Data Line 5
    8 DD10 Data Line 10
    9 DD4 Data Line 4
    10 DD11 Data Line 11
    11 DD3 Data Line 3
    12 DD12 Data Line 12
    13 DD2 Data Line 2
    14 DD13 Data Line 13
    15 DD1 Data Line 1
    16 DD14 Data Line 14
    17 DD0 Data Line 0
    18 DD15 Data Line 15
    19 GND Ground
    20 Select Selection for Pin 20
    21 DMARQ DMA Request (optional)
    22 GND Ground
    23 DIOW
    24 GND Ground
    25 DIOR
    26 GND Ground
    27 IORDY IDE device still busy (optional)
    28 Reserved Used for Cable Select
    29 DMACK DMA Acknowledge (optional)
    30 GND Ground
    31 INTRQ Interupt Request
    32 IOCS16 16 Bit data transfer
    33 DA1 Bit 1 Address bus, for addressing the
    Internal data register on the hard drive
    34 PDIAG Passed Diag Hard Drive self test concluded
    35 DA0 Bit 0 Address bus
    36 DA2 Bit 2 Address bus
    37 CS0 Selection Command Block Register
    38 CS1 Selection Command Block Register
    39 DA/SP Drive Active Hard drive is active / after slave drive
    Communicates its presence
    40 GND Ground
    Good find...probably would've been better to post it here than start a new thread...but oh well.
    http://www.mp3car.com/vbulletin/show...hlight=pinouts
    1999 Plymouth Voyager (That's right, big-pimpin' in a minivan.)
    PC built into console
    worklog with pics: http://www.mp3car.com/vbulletin/showthread.php?t=46359
    Some of my music: http://www.myspace.com/markquestion
      thats some strange ****in music!
        'T' is pretty cool...
          Heh, thanks. (Threadjacking sequence initiated).
          I've been making electronic music half-seriously for the past few years (I play bass and sing, and have been in bands for a while now. Recently, the last one I was in broke up.) I need to make music somehow, and since my band disbanded, I figured I would put some of my more "finished" (yeah...finished...sure) work up on the Intar-web.
