USB 2.0 issues PLEASE HELP!
  • USB 2.0 issues PLEASE HELP!
    I have a Commell LV-670 motherboard with the Intel 845 chip set. I love this MB and it boots quite fast. However i have a problem with usb 2.0
    The bios and MB support the usb 2.0 and i do have the enhanced usb line in device manager. All checks out... however when i plug any usb 2.0 device into the port it will not work.
    For example i purchased 2 Belkin tetra hubs. It has a light that will let you know the connection speed.
    When i plug it in the 2.0 light is lit but it will not show up in windows. When i disable 2.0 in my bios it will connect at 1.1 and work just fine.
    I tried installing all different drivers but none made a difference. Any usb 1.0 device i plug in works great, any 2.0 device will not connect unless i manually disable 2.0 in bios.
    I am running windows XP sp2 with the LV670 motherboard.
    -Jack
    2006 Chrysler 300C AWD
    Samsung Galaxy Tab In dash
    Are you sure you have the latest bios and drivers? (nice board btw)
      Latest drivers however only 1 version of bios. Ver 1.0
      -Jack
        hmmm does sound like a bios issue. Have you emailled the manufacturer?
          Hmm, look more closely at the BIOS maybe there's some weird setting that we're missing... For example telling the bios to use 2.0 or something..
          Progress [I will seriously never be done!]
          Via EPIA MII
          512MB RAM
          OEM GPS (embedded)
          nLite WinXP pro on
          1GB Extreme III CF card
          Carnetix 1260 startup/ DC-DC regulator
          Software: Still, re-Writing my existing front end in .Net
            I tried but no avail! There are 2 USB settings...
            1. Enable Usb host controller
            2. Enable High speed Usb 2.0
            Both enabled
            -Jack
              you tried just enabling 2?
                Wait a minute? Could that be? I think im going to have to try it!
                -Jack
                  any luck yet?
                    What a retard... hahahah !
                    Current Setup
                    Nexus 7 Tablet
                    Built in head unit
                    Brutus 1500Watt Amp
                    Two Boston 12" subs
                    2006 Infiniti M45 Sport ;) My 4 door Camaro... lol
                      Figures a jackass in a 610 hp Camaro would reply like this... I am not some damn noob who knows nothing about computers.
                      Anyway I do not have the option. When i disable the Usb controller it completley grays out the USB 2.0 option.. So you need to enable the Usb controller in order to determine if you enable or disable 2.0
                      -Jack
                        we don't need comments like that. so ***** off!
                        Kamakazie2, was worth a try. did you find an updated bios or USB2 driver from the manufacturer?
                          I emailed Commell yesterday, hopefully they will get back to me.
                          -Jack
                            What chipset does this mobo run off of? In my case, I had to install the VIA Hyperion chipset drivers to get my hardware to work properly. Good luck.
                            -HD
                              -HD
                              The mobo used the Intel 845 Chipset, i tried d/ling all of the intel drivers from their site. However everything says windows xp has it already. The driver is from 2002 and i am trying to see if there is a later one out there. Hopefully Commell will get back to me soon.
                              -Jack
