Ram fried PSU?
  • Ram fried PSU?
    i just installed some more ram in my old piii 450 mhz machine it has a 150w psu and was running a cdrw voodoo 3d gfx card ethernet and a 80 gb wd hd it used to have 64 mb ram now it was gonna have another 128 but when i went to power it back up i got nothing no fan on the psu nothing? is it possible the extra ram took this machine over the 150w ps it originally came with?
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
    Take the new ram out.... check that the 64mb are working....
    That happend you have bad RAM don't think that 'cause of the new one you pas you PSU Rate.......
    BTW check my thread for "industrial memory tester"
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Originally posted by bgoodman
    We're an international forum, post in whatever langauge you like.
      yea i tried that 1st no go 64 mb does nothing as well
      .______
      | '_ |__\___
      [(o)|___(o)] XB
      ._________
      | I__I I_I|_\__I
      CarPCNetwork
        Old machines like yours usually dont like itwhen you just stick a memory module with different size or clock speed in the slot. be sure to stick The 128mb RAM in the first slot and then the 64mb RAM on the second. You should get a fan spin anyways, but just in case!
        Time displayed in a different way!
        http://www.lares.dti.ne.jp/%7Eyugo/s.../03/index.html
        http://www.humanclock.com/
        FREE 3D Glasses: http://www.rainbowsymphony.com/freestuff.html
          hmm ill try that
          .______
          | '_ |__\___
          [(o)|___(o)] XB
          ._________
          | I__I I_I|_\__I
          CarPCNetwork
            tried that but all i get off of the psu is a flash of light on the ethernet after i plug it in then it goes black ...same thing that happens with the 64 mb ram by itself.
            .______
            | '_ |__\___
            [(o)|___(o)] XB
            ._________
            | I__I I_I|_\__I
            CarPCNetwork
              Hmmm you should probably start looking for a new PSU. Doesnt cost that much anyways. However, do you smell any burned electronics? Take the PSU apart and see if there is something "exploded". PSU Fan not spinning is usually a very bad sign!
                u think it may have taken out the mobo too cuz if thats fried then i dont even think its worth getting a psu grrr ...well only one way to find out i guess ..... time to hop in the car here we go.......
                .______
                | '_ |__\___
                [(o)|___(o)] XB
                ._________
                | I__I I_I|_\__I
                CarPCNetwork
                  Come on how much will a mobo like this cost? Maybe 10 bucks? Hope the mobo is ok!
                    DISCONECT ALL THE PERIFERALS AND TRY AGAIN!!
                    reset bios.
                    take the batt out.
                    Nissan Aux-in MOD
                      ok just did that took out the psu and no fan no nothing nothing connected to it not even the mobo . i need a bench testing psu for my new rig anyway not a total loss i guess
                      .______
                      | '_ |__\___
                      [(o)|___(o)] XB
                      ._________
                      | I__I I_I|_\__I
                      CarPCNetwork
                        ok so it was the damn cmos battery or something of the sort popped it out now it works at least for now maybe its low ill goget a new one just to be sure. odd tho cause i got a new psu and put it in and it was the same problem i should have spent more time trouble shooting then jumping to conclusions oh well i got a new psu yay
                        .______
                        | '_ |__\___
                        [(o)|___(o)] XB
                        ._________
                        | I__I I_I|_\__I
                        CarPCNetwork
