Newbie DVD Drive Question
  • Newbie DVD Drive Question
    Hey Everyone,
    I am in the early stages of planning my system, and am gathering a list of components I will need. Right now I am looking for a DVD/CD drive that I can install in one of my "mail slots" behind the passenger seat in my 350Z. It is about the size of a standard DIN opening, and I would like something that is black and slot-loading if possible. I suppose it needs to be USB powered, in order to connect to the PC that would be installed in the other slot. Ideally I could find a computer case that is this size with the drive in the front, eliminating the need for an external drive. Any recommendations for either?
    please. been talked about numerous times.
    since im a fun noob-loving joe (most of the time anyhow ), im going to start you off with a few search terms:
    "DVD Slot Load"
    "IDE USB"
    and as far as a DIN size complete carpc, iirc, there is one in the mp3car store. although it is longer than a standard headunit, so make sure you have enough room behind the dash for it.
    Your everyday carpc geek and tech guru at your service. *bow*
      DVD Drive
      Thanks, and I apologize for my ignorance but I think what I really meant to say was that I am really just looking for a whole system that will fit in my "mail slot" with a drive accessible from the front. The PC case I saw in the MP3car store had a photo that really wasn't clear enough to tell if the drive was in that position; I suppose I have to go ahead and measure the space I am talking about and repost. I will do my HW first next time, promise!
        has a spot for a slim drive and fits in a single-din slot.
          Well its a bit optimistic to say that it will fit in a din slot. It will probably stick out about 2 Inches....Depends on the vehicle of course...but it always does susually!
          Time displayed in a different way!
          FREE 3D Glasses:
            which is exactly what i mentioned in my first reply. width and height wise, it will fit a din slot just fine, but make sure you have enouigh room behind the dash for the length part of it.
              I think you should look at this thread here...
              Really though, the Z has so much room for stuff like this, unless you absolutely need to use the mailbox, there is lots of other space to be found. For instance there is quite a bit behind and below the glove box. There is the factory sub location if you happen to be lucky enough not to have the Bose system.
                Search the "Show off your project" forum for a Z install. You'll see where others have placed the hardware.
                Want to:
