Com Port Amp Trigger
  • Com Port Amp Trigger
    I want to make a simple program that on startup it will short some pints on the com port and stay shorted which will trigger a relay which will then turn the remote wire on to my two amps and this will allow me to avoid the amp pop. I know there are boards that do this with relays usb com etc but I only need one relay and doing it this way it would be basicly free...
    let me know of somestuff that might help I look around a bit but maybe someone can give me some help here
    thanks
    2005 Ford Mustang GT <- - - UPDATED PICTURES
    2003 KAWASAKI Z1000 - CUSTOM MODZ
    MBK (AIM = IllMBKllI)
    haven't you tried to ??? it's already been done. you're talking about the com port's dtr (data terminal ready) pin. you wire that to your amp. you download a program that gives the dtr signal after bootup.
    search for "windows service dtr".
    Brushed Metal for Centrafuse 1.4
    Brushed Aluminum for Centrafuse 1.4
    xenarc 700ts | via epia-m10k | audigy2 nx | holux gm-210 | usb wifi | 40gb 2.5" | slot-load dvd-cdrw | morex 3688 | opus 150w | centrafuse, iguidance
