Ignition Off Pop Stopper
  • Ignition Off Pop Stopper
    Ok SO I picked up an ignition off pop stopper made by stinger. I was looking at the wiring diagram and I am a little confused on how to wire it to the carputer.
    I dont know where to put the wire that goes to the HU in the diagram (the red wire) and also where does the white/red wire go to? It says to the amp so i guess the remote input of the amp?
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    I would guess that the red wire goes to the remote output of the headunit and the white/red goes to the remote input of the amp.
      but i dont have a headunit. My xenarc touch screen will be there
      Carputer Specs:
      Via M10K
      512mb Ram
      60GB HDD
      OPUS ITX PC Case
        so wire the red to a 12v power wire in the computer...
        But don't take it from me! here's a quote from a real, live newbie:
        Originally posted by Viscouse
        I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
        eegeek.net
          well is the red wire and the white/red wire a power wire or are they just remote wires?
          Carputer Specs:
          Via M10K
          512mb Ram
          60GB HDD
          OPUS ITX PC Case
            the white/red looks like a remote wire but the red wire is most likely a switched power wire. looks like there should be another ignition wire going to the delay though.
            rebuilding carpc... kinda..
              so where should i wire them too?
              Carputer Specs:
              Via M10K
              512mb Ram
              60GB HDD
              OPUS ITX PC Case
                anybody?
                Carputer Specs:
                Via M10K
                512mb Ram
                60GB HDD
                OPUS ITX PC Case
                  is the red and red/white ACC lines?? What do they do?
                  Carputer Specs:
                  Via M10K
                  512mb Ram
                  60GB HDD
                  OPUS ITX PC Case
                    why on earth did you buy this device?
                    Signature: [==||========] 20% complete
                      I bought it because i heard that alot of people have problems with the pop when they turn off there car....
                      Carputer Specs:
                      Via M10K
                      512mb Ram
                      60GB HDD
                      OPUS ITX PC Case
                        this device is supposed to stop the "pop" that an amplifier makes. the pop we get is from the computer which is fead through the amplifier, NOT from the amplifier itself. So if you are experiencing a "pop" from the computer this device will not fix it, well depending on timing it may but even then its way overkill.
                        Wire up your stuff without crap like this, and then if you have problems ask us and we will tell you how to fix them
