max usb hdd size?
  • max usb hdd size?
    hi guys, just wondered if there is any limit to the size of external usb hard drive i can use with my xp laptop as i can get a 300gig for 130. also it comes with a mains adaptor but a 12v and 5v supply in the car will run it i presume? thanks!
    PB 2.0Ghz, 20GB, 512mb, XPpro. 300GB Usb HDD, Griffin pwrmate, m-audio audiophile fw. BU-353 gps. 2x100w sony amps, 1x150w JBL sub amp, MBQuart front components, 6x9 rear, 10" sub. Audiocontrol epcienter, esp2, 3xs. Clifford G5, Finished, fitted, problems
    If it's USB you shouldn't have a problem. Does it have a straight power cord, or a power adapter? If it has a power adapter, look and see what the ratings are on it, then you only need to find that power. The USB board might use something different from 12v and 5v.
