Good Case for Mini-ITX w/Opus PSU
  • Good Case for Mini-ITX w/Opus PSU
    I have been searching all morning for a case that will fit an epia MII 1200 with an opus power supply. I am looking for something no wider than 8 inches and no longer than 15 inches. Has to fit under rear passenger seat.
    Any help would be greatly appreciated.
    If you wanna sell one, let me know as well.
    You can still have something if you have nothing
    Does anyone have any ideas for this.
      I'm also lookin for a case of a similar size for epia sp13000 with an opus supply, but have had no luck so far. Closest I've found was the travla c137 W-12.7" H-2.7" D-10". This might fit under my passenger seat, but will be a very tight if it does. Not sure I wanna risk wastin the money. I might have a go at trying to make one? Not sure how hard it would be, haven't looked into it yet.
      CarPC Status
      [|---------] 10% Complete
      Researching
      HomePC
      P4 2.4GHz
      1GB DDR RAM
      NVIDIA GeForce4 Ti 4600 256MB DDR
      120GB + 300GB HDD
      18.2" Eizo TFT
        If you can't find exactly what you need, making one isn't all too difficult.
        I got two sheets of 12"x12" 22gauge stainless steel from Home Depot to make a 8"x7"x4 enclosure to fit in my dash. I'll post a picture later, when I get home.
        Dr. Ron Paul for President 2008
        Hope for America - http://www.ronpaul2008.com
        Who is Ron Paul? - Why do we need Ron Paul?
        CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
          As promised, here are pictures of my case.
          All the edges of the case are soldered together, and it is rock-solid. The only thing you don't see in the pictures are the holes for the screws which hold the case together, and I also coated the case with an anti-rust coating because there was some flash rusting.
            Sweet case Tj!
            Travla C137 can fit under the seat, there are a few members that did this. Ofcourse, it depends on the car too...
            Renault Megane...the OEM look
              Thanks Cris =)
                Which Opus PSU? With a few easy mods a 90W Opus will fit neatly into a Morex 3677. See http://hi-techreviews.com/modules.ph...rticle&sid=635 for a review.
                Removing the Morex PSU and the standoffs will give you enough space to snugly fit the Opus. Note that this won't work with the almost identical Morex 3688 -- the little circuit boards behind its less deeper faceplate are sitting in the way (as can be seen on http://www.bigbruin.com/html/morex_3688.htm).
                CarPC status: HW all done, SW needs tweaked.
                Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
                Software: RR, MM/FD
                  First link doesn't work, and on the second you have to delete the ")" from the end.
                    Hm, first link works fine here...
                    I just finished editing the 2nd one
                    Software: RR, MM/FD
                      http://www.mp3car.com/vbulletin/show...ight=opus+3688
                      http://www.mp3car.com/vbulletin/showthread.php?t=22162
                      Opus will fit in the 3688 with modification
                      Technology, Gadgets and Making Money Online
                      http://www.genemills.ca
                        yes, I've seen that thread before. I don't like the idea of sticking the PSU upside down to the drive frame like that with blutac/playdoh/sillyputty/ducttape
                        Software: RR, MM/FD
                          ducttape...I hope that was only there for the test fitting....
                            oPUS 150 WATT, I am currently fabbing my own right now.
                              I have a mini-itx p4 motherboard (MB870), a 150W opus, 2.5" 60 gig drive, and an Audigy 2 NX all inside the case without any modification. I'm using the C137
                              I can grab some pics the next time it's out if people care. Basically everything fits well.
