Music skips when driving over bumps?
  • Music skips when driving over bumps?
    So, my music will skip (similar to a CD skipping) when I drive over any noticible bump. I have low profile tires and stiff suspension, so the ride isn't great, but I would imagine that if the harddrive skipped it would do alot more than make the music skip? I am using a laptop harddrive (inside the laptop, which sits on 2" of super plush foam!!) Something to note is that this is a 7200 rpm 40GB latptop hard drive.
    This is MP3 music btw, not CD's.
    I am pretty confident that the cables are all solidly secured, making it less likely for that to be the issue.
    Any ideas?
    Is the drive mounted vertically or horizontally?
      Horizontally in the laptop, which sits flat on the foam. Should I try it vertically?
        No, keep the hard drive mounted horizontally.
        I am not sure why it is skipping. I have heard of people practically going off road and they don't have any problem. Could it be an issue with the laptop drive?
          Why?
          Laidback
          The ultimate CarPC - Wow!
            Could you have a loose connection in your audio cabling? The bumps are perhaps cutting out the sound signal rather than your hard drive skipping.
            I agree that if your hard drive was skipping, you'd soon have much bigger trouble than sound files missing..
            Want to:
              Have you done a chkdsk on the drive? May be a simple problem on the filesystem
