Radeon 7000 with M10k Help..."input not supported"
  • Radeon 7000 with M10k Help..."input not supported"
    HI, I am trying to get a radeon 7000 to work with my carpc, but after it says "starting windows" both the carpc screen and a monitor (for testing) go black and the monitor says "input not supported"
    any ideas?
    I'm trying to get fullscreen in my fx, because right now through my nav-tv device it doesn't fill up the whole screen and I was hoping this pci vid card could do the trick...
    Peep MY TYTE WHIP yo! It's got too many ill mods to list!
    It mite be too powerful. I went with a Jaton 64mb from Newegg for $52 it works great!
    http://www.newegg.com/Product/Produc...82E16814139146
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
      really? someone told me to get this one because they used it in their carpc hmmmmm
      i got it from newegg for the same price pretty much.........
      what exactly do you mean by too powerful? like too many watts?
        Input not supported = too high refresh rate.
        PowerVoice v1 | NaviVoice Source
        GammaControl v2.4
        SKINbedder v3
        1995 Lexus SC300
          so what should i do? it's the first time i'm popping it in, so i can't exactly change it...
            safe mode.
            Now Galileo is real. Muhahahahaha :p
              Originally posted by DeltaFX
              safe mode.
              Exactly
              The computer POSTs with the car... right?
              GammaControl v2.4
              SKINbedder v3
              1995 Lexus SC300
                thanks but then what???????
                i go to safe mode and install the drivers, but when i restart it still says input not supported on my monitor. how can the refresh rate be too high for a regular lcd monitor?
                  Use different drives? Maybe go to the registry and edit the values. Or go get a refresh rate fixing tool.
                  GammaControl v2.4
                  SKINbedder v3
                  1995 Lexus SC300
                    change the resolution to 640x480 in safe mode manually and see if this fixes your issue
                    also check here for latest drivers. the way i see it is if it comes up in safemode then it is definitely a software problem... either drivers or settings
                    RIP 1993 civic sedan
                    RIP 1993 civic Del Sol
                    Hello! VW Golf 1.8t
                      res in safe mode is 640 by 480 already and you can't change it............ i'll play around today again, but hoping for other ideas.........
