usb extension?
  • usb extension?
    yo, is there a cord to extend the usb cable...
    for example... is there a cord to extend this plug(male on one end, female on other)
    im trying to put one of those in my glove box and my computer is in the trunk.
    http://card.mygamercard.net/gbar/car...theberetta.gif
    Just plug a USB extension into the end on teh bracket.
    Either that or do some splicing.
    How about the Wiki?
      Do some splicing, keep in mind the max length of a USB 1.1 card should not be much longer than 10ft or 15ft for a usb 2.0. Any longer may cause undesired functionality of your devices.
      You can still have something if you have nothing
        also, it's a little sketchy splicing usb... the ground wire usually turns into the shielding for the cable. I tried splicing just running four wires and my usb stuff freaked out on me...
        90% done - Sempron 64 2600+, MSI RS480M, 512mb, 80gb hd, 7" Lilliput, 802.11g pci, Itrek gps, Panasonic slim slot DVD/CDRW (broke :( ), Hauppage Wintv, Iguidance 2.0, Opus 150w, Griffin Powermate, Optima Yellowtop, Infiniti 6002i & 9603i
        My Install
          so i guess ill just have to use extension cables...
          thanks anyways guys
            if you can solder and crimp half-way decently you could do this...
            a couple of these...
            http://jameco.com/webapp/wcs/stores/...oductId=100811
            some of these...
            http://jameco.com/webapp/wcs/stores/...oductId=100765
            one of these...
            http://jameco.com/webapp/wcs/stores/...roductId=53495
            some shielded cable and heat shrink tubing... you could have an extension in an afternoon.
