Replaced Motherboard battery now no post??
  • Replaced Motherboard battery now no post??
    I have a small 5 1/4" socket 370 SBC that had a bad battery, The battery was soldiered in. I went to battery source and picked up the battery. Useing a low powered soldiering iron I touched both ends of the old battery heating up the soldier and just poped the battery out...it took very minimal effert and I soldiered in the new battery. Reinstalled the board and now the processor fan spins, but the board doesn't post, no beeps, nothing. I took the new battery back out, inspected the board to make sure nothing had gotten shorted. I couldn't see anything visible. I tried to power it up with the battery removed and still nothing. I have treid resetting the bios. still nothing.
    I was grounded during all the work.
    Any ideas?
    2003 100th harley F-150
    PCChips C3 VIA/eden, M1 ATX smart car.
    Here is my project so far: My 100TH Harley-Puter
    Ride safe
    Buy my stuff: Stuff
    Anyone have any ideas???????
    Ride safe
    Buy my stuff: Stuff
      you have the battery in the correct way?
      Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
      PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
      Toys:K8055 relay board, Elmscan OBDII
      Type-R Mini
        you may need to reset the CMOS
        connect (or disconnect) the jumper for the CMOS and let it sit for 30 seconds (battery connected)
        then put the jumper back and see if it posts
        [||||||||||||||||||||] - final touches
        SUPER 7" VGA w/ TS
        Toshiba Satellite 3000
        P3 850
        256MB
        30GB
        Geforce2 Go
        DVD
        Orinoco 802.11b PCMCIA
        nlite WinXP 350MB installed
        RoadRunner
        iGuidance 2.1
        Holux GM210 GPS
        Xantrex Xpower 300
          Yep, Only fits one way
          Ride safe
          Buy my stuff: Stuff
            Ride safe
            Buy my stuff: Stuff
              Anyone during the day time have any ideas?
              Ride safe
              Buy my stuff: Stuff
                tried to check the new battery with a multimeter? Might have killed it soldering
                alternativly has the solder taken properly (multimeter again, this time check from the board mountings)
                  Just checked it again to make sure. 3.7 volts, says 3.6 on the front so I am guessing it's good. Anything else? LoL
                  Ride safe
                  Buy my stuff: Stuff
