question on this product
  • question on this product
    Can this be used has a carputer and if no why??? thanks
    http://www.tigerdirect.com/applicati...810&CatId=1240
    http://www.tigerdirect.com/applicati...095&CatId=1344
    Anything that you have room for can be used as a carputer... plenty of people have full size atx boards in their cars... i did a little while ago
    what are your plans for this carputer?
    do you plan on using the TS of the s-presso?
    are you going with an inverter or dc-dc?
    I also reccomend you search for the "expresso" here... I know for a fact some people have used them. and maybe they're feelings on their adequacy will give you more insight into your purchase
    RIP 1993 civic sedan
    RIP 1993 civic Del Sol
    Hello! VW Golf 1.8t
      thanks for your info! but what is the benafit of using a VIA EPIA M10000 mini board vs. a bigger one! I'm planning to havd gps, tv, radio, and good sounding system from it, also to watch dvd, and maybe obd system in my car but would like to make it look good,, also what would be a good power suppy to use for a big or small set up!
        http://www.mp3car.com/store/index.ph...1f58c9ad768d64
        is a good place to look for PSU
        i personally am using a mATX p4 3.2 i think there are 2 benefits in using the epia boards... size and popularity, because they're so popular you can always find someone who may have experienced what you are.
        Hello! VW Golf 1.8t
          the benefit of a via epia board is that it's much smaller and uses much less power... if you search around a bit you'll find that probably the biggest headache in putting a computer in the car is powering it. for reasonably low-power systems, if you've got the $$, then you can get an opus and be done with it, for higher-power systems you will have to run an inverter and a standard ATX supply, at least until some of the new higher-power DC-DC supplies are released...
          But don't take it from me! here's a quote from a real, live newbie:
          Originally posted by Viscouse
          I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
          eegeek.net
            thanks evan for clearing that up lately I know what i want to say... but can't seem to put it down...
            Hello! VW Golf 1.8t
              thanks guys so if I buy the opus 150 i can run anything as a carputer! what do think about this set up!
              shuttle fn41 mb
              and xp2400
              Maxtor 80 gig 7200 rpm hd
              512 Micron ddr ram
              Opus 150 ps
              pioneer slim slot dvd/rw
              acer fire wire enclosure
              25 ft firewire cable
              ifree rf wireless keyboard
              Delorme usb gps
              microsoft streets 2005
              Microsoft xp pro with sp2
              Power dvd
              windows mediaplayer 10
              Hifonics Brutus BX1600 case
                Hey anky1, how is your set working for you I was lookng at your as well!
                  Hey L8back,
                  Why don't you instead of using a regular AMD proccessor, use an AMD mobile processor. You would be saving a lot of power by doing so only losing a tiny bit of performance.
                  Peace,
                  Rafster
                  Post # 3000
                    Originally posted by Rafster
                    Hey L8back,
                    Peace,
                    Rafster
                    I'll second that. Pentiums take a lot of power. Anything above 1Ghz with decent amount of ram and a fast HD should be enough for the CARPC use.
                    Current project ■■■■■■■■■■■■■■■■■■■■■■■■■■___ 85%
                    Xenarc 700TS, Mobile Athlon 1GHz, Soyo K7VME, 30Gb HD, Slimline DVD drive, TB Santa Cruz, Opus 120W
                    Holux G210
                    03 Acura TL, Zapco & Precision Power amps, Adire Koda comps & EDesign 12" sub.
                      So this system is not a good one the reason i asked is because soms is seling this system to me abou tlike to knew if it is a good set up??? And if you change the amd with a moble it would make it alot better??
                      shuttle fn41 mb
                      and xp2400
                      512 Micron ddr ram
                      Opus 150 ps
                      Delorme usb gps
                      Power dvd
                        I am in lust with my dell, having 3.2 p4 and 1 gig ram is wonderful... except the need for the inverter... I am anxiously awaiting a 200watt DC-DC
                        Hello! VW Golf 1.8t
                          shuttle fn41 mb
                          and xp2400
                          512 Micron ddr ram
                          Opus 150 ps
                          Delorme usb gps
                          Power dvd
                          You can run any ATX-spec setup that draws less than 150 watts.
                          I think you should go with the mobile version of the same CPU, but other than that you should be golden. The only other issue might be the 7200rpm HDD. They can draw some hefty power spinning up.
                          How about the Wiki?
                            not a fan of MS Streets and trips personally i dont like certain things about the U/I
                            what is the firewire for?
                            what about a screen?
                            also which front end are you planning on using?
                            Hello! VW Golf 1.8t
                              Not exactly. You can run anything that stays under 150 watts. Search on terms "Power Calculators" or go to the FAQ Emporium and look at the thread on power supplies for links to calculators.
                              Want to:
