How can I access extra USB ports on EPIA MII-12000
  • How can I access extra USB ports on EPIA MII-12000
    I've got me self a VIA EPIA MII-12000 mobo and installed WinXP.
    When I go to the device manager it says that I have 3, yes 3, USB Root Hubs.
    Now I'm assuming 1 hub is servicing the 2 USB ports on the back panel.
    So what are the two others? More importantly, can I use them? Cause what I whant to do requires from 5 to 6 USB ports and, if at all possible, I dont whant to use an external USB Hub (from what I read, they dont seem to work so great).
    Any hints???
    [■■■■■■■■■■■■■■■■■■■■] 50%
    PC installed
    EPIA MII-12000, 256DDR, Opus 150, Xenarc, 30Gb/7200 HD, USB Wifi.
    Waiting for: GPS & Soft, eternal Sound Card + Amps.
    check the manual, there is a connector on the motherboard (near the FDD connector) that is your other usb connector (it is not a normal usb connector, but a row of 5 pins next to a row of 4 pins). you want to connect something likethis to that plug.
    |V1 Virtual Display|
    Hard work often pays off over time, laziness always pays off right now.
      Sure you can use them (for a total iof 4)
      RexBruMet Skin for FrodoPlayer
      Nissan Aux-in MOD
      Originally posted by bgoodman
      We're an international forum, post in whatever langauge you like.
        Doh! It never occured to me that there where extra connectors directly on the mother board! I just looked them over and this mobo is packing (at least for my needs)!
        Even better now that I have found a CF GPS receaver. Now I only need 4 USB ports. so no more need a USB hub!
        Excellent, truly thanks!
        PC installed
