Power Switch
  • Power Switch
    Hey I was just wondering it is possible to put a switch on the power cable going to the opus? The power as in the direct power cable from battery. IF not where can i put a switch besides on the remote like cuz i already go one there. IF the car PC ever "FREEZES" and stops respondingm if i flip that switch on the remote line wiht the pc eventually turn off? I have a 10second turn off delay....
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    I dont see why not
      I would recommend the use of a relay, you don't want to be switching that high current wire directly from your dash.
        Well i would wanna be able to cut the power to the pc and then flip it back on....basically to turn off/turn back on
        Carputer Specs:
        Via M10K
        512mb Ram
        60GB HDD
        OPUS ITX PC Case
          Searcht he forums. I know this has been addressed. If I remember correctly, there's even wiring diagrams to do exactly what you want.
          How about the Wiki?
            A relay allows you to use a low current (safer to run to dash) to switch a higher current (not so good to run through dash)
            http://www.the12volt.com
            lots of schematics there
              Why don't you install a regular power switch from the mb (like the case has) and just hold it down for six seconds. It should shut the power supply off and then you could turn it back on immediately.
              - Jeff
              edit: I just saw that you have an ITX setup - I don't know if they work like an ATX power supply...
              95 Mustang GT Convertible
              87 Mustang GT Convertible
              My Project | Let's Go Mets! | SCT Tuners
              Project Status [===#===] [Bezel and dash creation]
