Temp Sensors
  • Temp Sensors
    Hey I was just wondering....What would be good software / and hardware to monitor the temperature inside my PC case / trunk and the inside/out of my car?
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    Use Motherboard Monitor 5. Freeware, and best thing out there!
    also known as mbm5 google it!
    EDIT: It will monitor everything related to your CASE. Sorry, know nothing about outside temperature monitoring...
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
      Already using mBM5 but it sucks. It doesnt give me accurate temps....
      Carputer Specs:
      Via M10K
      512mb Ram
      60GB HDD
      OPUS ITX PC Case
        Sorry to hear that. Works very well for me, and is insanely configurable. Its what most folks use in this forum.
        2002 Honda CR-V
          IM thinking about doing a Phidget setup. With an 8/8/8 controller fo $100 And Get 4 analog temp sensors to connect to it.....
          Carputer Specs:
          Via M10K
          512mb Ram
          60GB HDD
          OPUS ITX PC Case
            How hard is it to work with Phidgets? Installing them and programming them?
            Carputer Specs:
            Via M10K
            512mb Ram
            60GB HDD
            OPUS ITX PC Case
              If it does no give you accurate temps ypu can change the sensor type in the program and see if it gives you better results
              Lilliput 7" TS TFT, ASRock K7VM2, Duron 1,3 GHz, 512 MB DDR RAM, 30 GB Seagate HDD @ 5.400 rpm, WLAN w/ 500mW booster, Toshiba Slimline DVD-ROM Drive, D-Link USB Radio
              Download the German Voicepack 1.0 for FreeDrive now!
                I agree, MBM5 does suck the proverbial, but it is freeware and well you can't be free.
                If you were going for a custom solution, I would look at the Dallas Temperature Sensor series. I've built some embedded temperture monitoring solutions for people using these things and they are AWESOME.
                Very easy to string a few (or many) together for an insanely verbose temperature monitoring system
                Caputer Mk. II
                '02 VX Holden Commodore Series II Executive
                MII12000, 512MB RAM, 60GB HDD (5400rpm), 16X DVD, TS200V
                Morex 60W DC-DC, Custom S/SDC
                OS/Software: Developing...
                  Hey thanks for the info, I tried Googling Dallas..... but couldnt find there main site. Can you send me a link of there products and where i can purchase them.
                  Carputer Specs:
                  Via M10K
                  512mb Ram
                  60GB HDD
                  OPUS ITX PC Case
                    I found something at QKits.com But i dont believe this unit comes with any software. How would i get it to tell me the temperatures?
                    Carputer Specs:
                    Via M10K
                    512mb Ram
                    60GB HDD
                    OPUS ITX PC Case
                      MBM 5 is as accurate as the winbond monitoring chip on the mobo is.
                      http://www.madhacker.org/mbmsensors.htm
                      Now Galileo is real. Muhahahahaha :p
                        Phidgets are cake to program with in VB. I have the setup you're thinking about. I am using it for climate control in my car.
                        - Jeff
                        95 Mustang GT Convertible
                        87 Mustang GT Convertible
                        My Project | Let's Go Mets! | SCT Tuners
                        Project Status [===#===] [Bezel and dash creation]
                          uhh how can it NOT be acurate? its reading from your motherboard directly
                            Dallas semi makes some chips you can connect to the smbus on your motherboard and MBM will reckognize them
                              Well, My CPU Temps fluctuate. First they are at 98 degrees an it 2 second it jumps to 115 then 20 seconds later it jumps from 115 to 95. It would take a long time for it to jump/decrease that fast
                              Carputer Specs:
                              Via M10K
                              512mb Ram
                              60GB HDD
                              OPUS ITX PC Case
