my setup
  • my setup
    after doing a lot of research and asking a few question on this board i think i am ready to start buying my CarPC. this is my setup.
    Asus A7N8X-VM
    AMD Athlon Mobile 2500
    2 PNY Optima DDR333 PC2700 256mb OR 1 512mb (advice please)
    Maxtor 80gig 7200rpm hd
    WinFast TV 2000 XP
    XP Pro
    XMDirect
    USB GPS Reciever (not sure which one yet)
    IGuidance
    Frodoplayer
    OBD2 Interface
    Linksys Wireless (not sure which one or type yet)
    OPUS 150w DC-DC PSU
    Slot load DVD/CD-R
    Lilliput 7" Touchscreen VGA
    Custom Case
    not sure on cooling extras yet but most likey a fan or 2
    i am going to have basically the same setup as a few other members on here but i forgot exactly who. how does this setup sound? any comments or sugestions?
    Asus A7N8X-VM
    WinFast TV 2000 XP
    XP Pro
    XMDirect
    IGuidance
    Frodoplayer
    OPUS 150w DC-DC PSU
    Custom Case
    It looks like a good plan. Very similar to my setup. (Note to self: Must order CPU next week ater payday!)
    The only thing that may be an issue is the TV card. It might push your power draw over the limit for the Opus.
    How about the Wiki?
      will using a different card be better or all in general?
        I don't know for certain that the card will be an issue or not. It might. It might not.
        I'd suggest getting the setup together without it. POwer it off the Opus. If all is happy and stable, add the TV card. If it's still all happy and stable, then you know it's not a problem.
        How about the Wiki?
          anyone else think this is a good setup? i want to start buying everything this week so i want to make sure this is it.
            Very smilar setup to mine as well, I think you should be ok. Take Darque advice about the TV card.
            Installed
            Asus A7N8X-VM - AMD Mobile Athlon 2400
            512 Ram - 60GB HD - Opus 150w
            Lilliput 7" - Rikaline 6010
            [00000000000001100010-] 98% Completed
            Check Out My Install!!!
              what should i use for FM radio than?
                any input on this? i want to start buying some stuff soon so i need to be sure this is a good setup or i should change something.
                also what would be better. the 2 256mb ram or the 1 512mb?
                  You might want to drop it down to 128MB or 256MB ram... It will speed up your resume from hibernate (if that's what you're planning to do). Only up the ram if you absolutely need it...
                  IMHO, I use memory hogging programs far less often than I turn the thing on. When driving to work or to the store, all I care about is how fast it boots.
                  Oh, always buy a single chip (unless the mobo/chipset requires doubles) - it will provide for more expansion in the future.
                  http://www.jeepmp3.com/
                  CarPC Stolen. Starting over.
                  Ne1 recognize the avatar?
                    But since he is running XP I would suggest he stays at 512, from my experience XP runs much better with 512 then 256. 126mb would be just too small.
                    Installed
                      256 is more than enough for me - I run frodo, IGuidance, and a few other apps with no problem.
                      If I were using the system for gaming, I might consider going with more, but I don't want to risk an extra second or two boot up for something which won't benefit me much during operation. (I haven't benchmarked how long it actually takes to resume - I'm assuming it will take longer)
                      If you're uncertain, go for two 256 sticks - pull one out if you don't see much benefit from using it...
                        thanks i think i am going to try the 256mb and if i need to up i can always add another one down the line. with all the apps i and everything i want to run, do you think this setup is good for the 150w dc-dc psu? to sum it all up this is what i plan on doing with it:
                        MP3s
                        DVD/CD-R
                        FrodoPlayer
                        FM Radio
                        XM Radio
                        PhoneControl
                        Internet
                        GPS (IGuidance)
