Vibration dampers for HDDs (GEL based)
  • Vibration dampers for HDDs (GEL based)
    Just wanted to share a link with you.
    I believe they can significantly improve the lifetime for HDDs in the car:
    Anyone have them or seen ones ?
    Car pc integration with ease
    Car mediacenter
    Very good find.....
    Any pricing?
    How about the Wiki?
      The guys at have these for their TIVO 2nd drive install kits which run about $10 / kit and include a nice piece of aluminum to mount the drive to with these vibration mounts.
        Can't find the priduct there, have a link?
          Did a little lookin around and found this:
          Not sure if it's exactally what you're looking for, but there it is.
          Progress: On hold while I pay off my new PowerBook :D
          Part List:
          VIA MII10000 - 512MB - 20Gig 2.5" - Rikaline 6010 - 7" Lilliput - CNX-P1260 - Alpine 4ch Amp - 4 Gauge wire and fused distrobution block.
              Originally posted by CJ8501
              I'd rather buy a backup HD!!
                okay well THAT is a total ripoff. I bet if you were crafty you could just make your own. after all you can buy 100% silicone at home depot, etc... just make a simple mold (you could probably use a small cap from a hair spray can or something as a mold), put a metal bushing in the middle, and fill it up with silicone...
                it'd take a long time to dry, and you'd have to experiment with different liquids to use as a mold release, but it would cost you all of $3 instead of $80...
                But don't take it from me! here's a quote from a real, live newbie:
                Originally posted by Viscouse
                I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
                  wonder how they compare to some 30 cent neoprene washers from home depot and/or cutting up one of those silicone gel mouse pad wrist rest things
                    if you can get your hands on an old/broken CDROM or DVDROM drive, open it up. The carriage for the head is on four rubber shock absorbers. That's what I'm using for shock absorption. Cheap and effective without fear of too much rebound.
                    Gen 1: Pentium 3 1GHz - ATX - 2005
                    Gen 2: Pentium M 1.6GHz - ITX - 2006
                    Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
                    Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
           never ends
                      they would dispatch a kit for free if you argument is convincing
                      just try it.
                      got mine like that.
                        Very old technique :
                        Cheaper way of doing it, been working fine for nearly 6 years for me :
                          I went to the hardware store and bought some of those silicon bumpers you put on knick knacks and other things you don't want rattling around. They are adhesive backed as well so they stick to the drive. I just drilled a hole through them and mounted 'em up. Total cost was about $1.79. No fancy brass bushing though.
                          Does that mean the brass bushing is worth $78.20??
                          Biostar M7NCG 400 ver 7.2 AMD Mobile Athlon 1.1GHz (@ 1GHz), Kingston PC2700 512mb WD 80gig HD Custom Case Opus 150W PS Lilliput 7" TS D-Link DBT-120 BT D-Link DWL-G122 WiFi Holux GR-231 GPS nLited XP Pro iGuidance RoadRunner frontend
