Mounting mobos to wood summary
  • Mounting mobos to wood summary
    I thought I'd collect a couple ideas I searched for into 1 thread. I have a wood/harboard case, and was looking for ways to mount the mobo to it. I found a lot of great ideas from lots of members. They get all the credit for these ideas.
    A1. Screw right into wood. Use standoffs, grommets or carpet as a spacer. This requires wood to be thick enough to allow screw to thread into it, but you won't see it from the outside. Several folks have done this with no problems.
    A2. Use PCB mounting feet as shown here: http://www.happcontrols.com/amusemen...r/49101900.htm
    A3. Use long machine screws with nuts. Screw goes into wood from outside, passes through standoff into motherboard, and terminates with a nut. This is good for thinner wood like hardboard, but screws will show on the outside.
    Not rehashing, just collecting. Hopefully searches will land you here.
    Also, need a quick cheap way of making grommets? Cut up a pen. An idea from a parts supplier.
    Sadly, I'm not the most creative guy on the plant.
    Here's a great thread: http://www.mp3car.com/vbulletin/showthread.php?t=45494
    You know you want to...Worklog
    Enjoying v1.0 since it's operational. Aaaawww yeah.
    Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
    Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
    Good tips.
    This might be useful in a FAQ, or perhaps it's a candidate for a new forum - though I wonder if there's enough interest in a "cases" forum.
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
      i just took the motherboard mounting tray out of the case and cut it down. then screwed that to the wood and mounted the m'board to the tray
      My install... check it out!
      www.mp3car.com/vbulletin/showthread.php?t=56599
        Use something called "T-nuts". Basically what you do is drill a hole in wood, than put the T-nut in from behind. It is a metal threaded unit, that has a lip on the outside that dig into the wood to prevent it from spinning.
        They're awesome, any fastner store should carry them.
        -JokerF15
