EPIA M10000 + Carnetix 1290 + PW-200 -problems
  • EPIA M10000 + Carnetix 1290 + PW-200 -problems
    I can't get the EPIA to boot with the board hooked to the PW-200 and a 12V AC Adapter plugged into the wall. Haven't test it with the 1290 yet. I have one 2.5 HDD and one slim 8X DVD to add to it but for now no booting once I plug an ATX power button on it. The board was just sitting on the plastic -like protective sheet that came with the box and not mounted to anything yet. Do I need to mount it before it'll function? If it's like all other ATX boards it shouldn't.
    Any ideas what it could be?
    99 Grand Prix Grand Tigress
    HW
    Liliput 8in TS
    845GVD MITX w/ 2.4 Mobile P4M (478 MB)
    60GB 2.5" HDD
    MS MN-710 WifiG
    BT Deluo lite GPS
    IrDa PS/2 Keyboard
    SW:
    Win XP SP2
    RR
    IGuidance 4.0
    Zots day skin
    Proscan 4.0
    (100% Complete!)
    It should boot with just power supply and switch connected . have you tried it with a regular power supply?
    PC Chips 1500,512mb ddr,no case yet, LinITX 7" touchscreen,300w inverter,RoadRunner FreeDrive,BU303 gps mouse.
      I have a 400W ATX but won't that be overkill?
      HW
      Liliput 8in TS
      60GB 2.5" HDD
      MS MN-710 WifiG
      BT Deluo lite GPS
      IrDa PS/2 Keyboard
      SW:
      Win XP SP2
      RR
      IGuidance 4.0
      Zots day skin
      Proscan 4.0
      (100% Complete!)
        nope thats not overkill, it'll be fine with a larger psu.
        REBUILDING!!
          Cool, I'll try it out,
          HW
          Liliput 8in TS
          60GB 2.5" HDD
          MS MN-710 WifiG
          BT Deluo lite GPS
          IrDa PS/2 Keyboard
          SW:
          Win XP SP2
          RR
          IGuidance 4.0
          Zots day skin
          Proscan 4.0
          (100% Complete!)
            How much power does that 12V adaptor provide? It probably doesn't put enough out.
            The 400W ATX power supply only means that it CAN put out 400w if the system asks for it. If the system needs less, that's all it will supply. It ought to be okay.
            Want to:
              It's a Kensington 33173 so I guess 70W
              http://www.circuitcity.com/rpsm/oid/...Review.do#tabs
              HW
              Liliput 8in TS
              60GB 2.5" HDD
              MS MN-710 WifiG
              BT Deluo lite GPS
              IrDa PS/2 Keyboard
              SW:
              Win XP SP2
              RR
              IGuidance 4.0
              Zots day skin
              Proscan 4.0
              (100% Complete!)
                From a review at the link you supplied:
                "90 watts? yeah right. printed on the back of the unit '65 watt max' on AC and '70 Watt Max' on DC. It's a 70Watt unit. If you only need a 70 watt unit, it seems like it would be ok."
                Try the 400 watt unit and see. Its not clear this one has enough juice. Or return it and get this.. I think it costs the same or less.
                Want to:
                  that is probally cutting it very very close as far as power goes. Did you try and get the mobo to post without anything plugged into it (thats usualy a good place to start, then plug things in and narrow the problem down)?
                  REBUILDING!!
                    In his post he said 70w
                    REBUILDING!!
                      Couldn't get a "The Source" aka Radio Shack of Canada to find that Part #....any other ideas for a plug in style?
                      HW
                      Liliput 8in TS
                      60GB 2.5" HDD
                      MS MN-710 WifiG
                      BT Deluo lite GPS
                      IrDa PS/2 Keyboard
                      SW:
                      Win XP SP2
                      RR
                      IGuidance 4.0
                      Zots day skin
                      Proscan 4.0
                      (100% Complete!)
                        Discussion on powering system in your house.
                        Also, try Froogling them up.
                        Want to:
                          Thanks!
                          HW
                          Liliput 8in TS
                          60GB 2.5" HDD
                          MS MN-710 WifiG
                          BT Deluo lite GPS
                          IrDa PS/2 Keyboard
                          SW:
                          Win XP SP2
                          RR
                          IGuidance 4.0
                          Zots day skin
                          Proscan 4.0
                          (100% Complete!)
                            looneeii,
                            Are you sure the Kensington puts out +12V? Do you have a digital voltmeter you can check with? If it's not +12V +/-5% you may be frying your mobo since the PW-200 sends the input voltage directly to the mobo.
                            MikeH
                              It ran my Xenarc MP-SC1 just fine...
                              HW
                              Liliput 8in TS
                              60GB 2.5" HDD
                              MS MN-710 WifiG
                              BT Deluo lite GPS
                              IrDa PS/2 Keyboard
                              SW:
                              Win XP SP2
                              RR
                              IGuidance 4.0
                              Zots day skin
                              Proscan 4.0
                              (100% Complete!)
