On Boot NTLDR is missing
  • On Boot NTLDR is missing
    What is NTLDR?
    Yea thats right look at the custom title.
    No really tho im searching right now, just seeing if i can get a quick response.
    Thats only half true...
    The windows NT loader.
    I think your boot record is screwed up. The easiest solution to the problem might be to run the windows xp recovery command from the install cd.
    Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
    Unlimited Internet and gps tracking for $6 a month with boost mobile!
    Carputer 2: www.lmaocar.com
      That really should be renamed to "Eject floppy disk or CD and try again"
        If you can find a way to defrag your drive that may fix it. Theres a lot of info on this problem on Microsofts knowledge base. I had it happen to me before. I defragged and it was fixed. Sometimes windows will move the file or fragment it. When that happens it can find it anymore. Usually happens from improper shutdown or powerloss. Defrag or recovery should fix it.
        The end of the Internet offically begins here...
        www.broke-off.com
          load recovery console and copy it off your windows cd into your c:\ root
            yea i checked the cables
            i copied the two files
            i ran fix boot
            i ened up just formatting it AGAIN and im reinstalling windows.
            hope it works!
              the format worked! Back to the worklog
              Thanx bunches folks!
              TK
                TK
                Format the drive. Guaranteed to fix just about any problem with Windows.
                Derek
                Progress [||-------]
                View my Worklog to see some of my progress.
                Downgraded Progress - Starting with another car... 09/13/06
