Cheap usb hubs?
  • Cheap usb hubs?
    I need some cheap and reliable usb hubs (two of at least 4 ports)
    I real realy wish they made a 10 port usb hub.
    search on newegg
    I got 4 Jahts or something off there for like 6 or 7 a peice, i think
    They run really hot when powered but work.
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
      they make em in 4 port because
      most standard usb devices use 100mA
      a usb port puts out 500mA
      the hub uses 100ma to do its work
      so 4 ports at 100mA plus the hub = 500mA
      View My Blog
      Click for 2GB FREE on-line storage!
        They make 7 port hubs. you should be powering your hubs anyway instead of the computer providing power. If you continue to add USB devices this could turn into a problem.
          Total ports ever used would be 10 so I'm hoping I can manage with two buss powered hubs to get the 8 minimum ports needed.
          If I am going to have to power a hub then I want a single 10 port usb hub that I can power from my 12v line. As far as I know 10 ports should be no problem for usb (asuming it was powered)
            Tigerdirect.com
            Thanatos.
            RexBruMet Skin for FrodoPlayer
            Nissan Aux-in MOD
            Originally posted by bgoodman
            We're an international forum, post in whatever langauge you like.
              Here is some of what will be pluged into the usb ports.
              Asus usb wifi
              zonet usb bluetooth
              keyboard (could get a ps/2 if need be)
              PS2 to usb adaptor (using the analog as a mouse)
              1-wire to usb adaptor (temp sensors)
              IR to usb adaptor (for remote control)
              Touch screen
              Memory card reader.
              Actualy that is all I need plug in at this point but it would be nice if I had one free port to jack in my pen drive and such. I would guess the wifi and bluetooth are the two power suckers in the list.
