Starting a project, need help
  • Starting a project, need help
    Ok, I have done a lot of reading on this post lately. I am about to start my own carputer project and I was hoping someone could just look it over for me and tell me if there is anything else I need and if it will work ok.
    Also I was wondering, do you have to have a case for it or can I just mount everything in my glove box and just make a cover plate for it? I really dont want to spent $100-200 for something that I will just cover up.
    I plan on eventually adding a GPS and the primary use is for playing music and watching movies. The monitor I will be using is one that comes with my air ride management and is touchscreen.
    This is what I have planned:
    OPUS 120W DCX3.120 $128
    VIA EPIA M10000 Mini-ITX Mainboard $158
    Transcend PC2100 DDR266/512MB $095 Logicsupply.com
    Panasonic Slim DVD-CD/RW $090
    3.5" Samsung 160GB Hard Drive $095 Logicsupply.com
    Thank you in advance for any help.
    sorry for the triple post, my computer is screwed up and I didnt think it posted.
      You might consider a 2.5" laptop hard drive to reduce the power draw even further. It may or may not be an issue.
      How about the Wiki?
        Is the existing monitor VGA? What type of interface does the touchscreen have usb or serial?
        If not then you might have a tough time integrating the LCD and touch screen with the computer.
        Progress [I will seriously never be done!]
        Via EPIA MII
        512MB RAM
        OEM GPS (embedded)
        nLite WinXP pro on
        1GB Extreme III CF card
        Carnetix 1260 startup/ DC-DC regulator
        Software: Still, re-Writing my existing front end in .Net
          I'm not sure of what type of connections the monitor has yet. I am waiting for a reply from the company I am buying it from. Cant it be hooked up with a S-cable or RCA's? I think I remember reading something about RCAs being bad for text, but I dont remember anything about S-video cable.
            I doubt that the touchscreen system that you current (/will be getting) will be compatible with the computer. I was looking at a touchscreen system to control airbags on my car. But I think that the system uses a proprietary touchscreen system that will not be able to feed in to the computer.
            Instead of the touchscreen system that was being sold, I was looking for a application that could control the airbags from within the computer (an external app) but I have not had much luck and I have zero programming experience.
            Derek
            Progress [||-------]
            View my Worklog to see some of my progress.
            Downgraded Progress - Starting with another car... 09/13/06
              i just found out that the screen only has rca inputs. will that be alright for the computer? also i'm not too worried about using the touchscreen for the computer. it wont bug me too bad if that part doesnt work. thank you all for the help
