Boot up
  • Boot up
    I get this warning when i boot my carPC Primary slave hard disk S.M.A.R.T status bad warning immediate backup your data and replace your hard disk drive a failure may be imminent
    can you help pleas
    Thank you
    sounds to me like you should
      Hard Drive is knackered mate - time to backup asap and get a new drive/warranty replacement.
        That means that SMART, the hard drive diagnostics, has detected that the drive is close to hardware failure. SMART also often times misdiagnoses, your best bet is to backup your data and run the drive manufacturers diagnostic utility to see what's up.
        # cd /home/fuzzymuzzle.com
        Intel Pentium M Dothan 750 1.8GHz 533MHz 2MB
        iBase MB896F w/ Intel 915GM
        [■■■■■■■■■■■■■■■■■■■■] 50% Done
        (Writing Front/Back End, Designing Electronics, and Completing Install)
