Via Epia SP - upgrade bios - how?!
  • Via Epia SP - upgrade bios - how?!
    Hi!
    Via Epia SP has no connector for floppy. But on http://www.viaembedded.com there is only awdflash utility supported by DOS based opeartion systems (no support for W2k, XP...). So, how to upgrade it?
    Thanks for advice!
    Uros
    System: VIA EPIA EN15000,512 MB DDRII,M2-ATX,300GB HDD,XENARC 1020TSV,VoomPC case
    USB: Powermate,WinTV+FM,WLAN 54G,Bluetooth,Haicom GPS mouse SIRFIII
    Software: Windows TinyXP Rev06+MinLogon+EWF+HORM+Centrafuse 1.2
    Honda delSol project
    CarDomain
    Google bootdisk.
    You should quickly find a few ways to make a bootable CDROM with your BIOS update on it...
    HTH
    Mike
    1998 Volvo V70 R AWD
    2.3L Turbo @ 17psi, 20% Tint
    SP-13000, 7" Lilli, Opus 120, 120GB SATA, Holux GR-213, Headrest LCDs
      Any USB floppy drive will do fine. Just make sure your BIOS can boot from a USB device (most modern ones can). I did this and it worked fine.
      aiml27
        Make a bootable CD...
        How about the Wiki?
