Upgrading to AMD Mobile.. but what case?
  • Upgrading to AMD Mobile.. but what case?
    I'm gonna upgrade from my current via 800 to a amd mobile processor/mobo combo. The one i'm looking at in particular is this:
    http://www.geeks.com/details.asp?inv...2600-N&cat=MBB
    What i need to find now is a suitable case for this. I was hoping there was a place i could buy a shuttle case but i havent found anywhere selling them. What cases are you guys with the mATX using. N while ur at it gimme a yay or nay on that setup above.
    Live mp3Car Facebook Chat
    The Shuttle cases are designed specifically for the Shuttle SFF motherboards. They don't conform to any standards.
    Realistically, any mATX case should work for you. Make certain the CPU cooler you're going to use will fit.
    How about the Wiki?
      I got an Athenatech A100SC.200 case for my mATX board. Includes a 230W power supply. $42 at newegg
      http://www.newegg.com/Product/Produc...82E16811190003
      Are you not in the US or something? I'd do another search for that one, they're easy as hell to find. I don't know if Shuttle is necessarily mATX form factor.
      GA-K8VM800M, Sempron 64 2800+, 512mb DDR400, D-Link USB BT, Linksys .11g NIC, 250gb IDE, BU-353, SIR-ALP1 w/ MJS, DSATX 220w, DWW-700H
      Worklog: http://www.mp3car.com/vbulletin/showthread.php?t=65059
      Now with pictures!
        I got mine from newegg too...I posted pictures months ago.
        These should work well:
        case 1
        case 2
        If you like the shuttle form factor then this should appeal:
        case 3
        Edit: they seem to have my case (but mine is red) too:
        my case
          thanks for the link pip. I think i'm gonna pick up the case you have. Any PCI clearance issues?
            Wont take full height PCI cards...make sure any PCI cards are low profile...or get a differen case if you have full height PCI cards.
              I've had similar cases before. I assume either hacking the metal bracket or removing it all together would work?
                I dont that that is actually a mobile processor on geeks.com
                if you pull up the CPU specs you will see that it is listed as 1.65 for the VCore. someone else on the forums bought it bu i cannot remember if a strait answer was ever obtained on whether or not it really is a mobile.
                My Install
                Software:
                CFiG v1
                iGuidance Plugin for CF
                CarShell
                Working shell for a CarPC
                StopWatch
                StopWatch plugin remade for centrafuse RC1
                  Either remove the bracket...or fab a short one.
                  You can still use a regular Athlon....I switched my Mobile Athlon to my desktop so I could really overclock it. I didn't even underclock the desktop Athlon...but if your power supply isn't up to it you can just underclock it.
                    I went from a P4 system to an Athlon system and even with my 150watt OPUS and minimal power drains from the PSU, the Athlon would not boot up.
                      yup and it was me that pointed it out. It is a 'desktop replacment CPU'. ie an unlocked desktop cpu for over/underclocking. Don't get it if you plan on running an opus 150W
                        I'm running a standard atx power supply with an inverter and the uSDC20 zootjeff sells. I'm not really worried about power constraints i was more getting it for the thermal aspect of it. Not to mention for that price even if it was a desktop processor and mobo it looks good to me. Whether or not it survives generally mild winter/summer seasons is my main concern.
                          Hey Sonicxtacy02! How is that Biostar board working out? I just bought that same combo from them and am curious if it was a mobile processor. Any suggestions in terms of using this board? Thanks!
                            hey do you know if it supports s3 standby?
                            REBUILDING!!
