ampie case fan in the way
  • ampie case fan in the way
    im using a 2.5 to 3.5 adaptor and it prevents the case from closing. if i take the fan out it will close perfectly. im running a mii12000 with m1atx and 512 ram...you think ill have a problem if i take the fan out? opinions? anyone try it. im lazy and dont tell me to search i been putting the damn thing together for my buddy for the past few hours. thnx guys
    i got dat ***** sittin on 22s! SUPERMAN EDITION!
    If you try it, make sure you report back. Boris
      ok guys i got it. basically what i did was change the fan on the cpu cuz its thinner and use the thicker case fan on the cpu. the thinner fan still is like 2mm too big to fit so i mounted it on the other side of the metal right behind the plastic. fits perfectly like a charm and everything works beautifully. thanks for looking guys. see this thread went from a Question to a HOW TO lol
