Power switch question
  • Power switch question
    ...maybe a simple question, but I want to run a switch from my mobo and mount it on my dash somewhere that would turn the power on/off to my pc. What kind of switch do I need. I was using the hacked power button from an old tower. I thought I needed a momentary switch but that didn't work so well.
    The switch would run to the pins on my mobo if that helps.
    A normally open momentary switch.
      If the cable run is long, you might get better results from a relay and switch.
      TruckinMP3
      Read the FAQ!
        It's actually called a 'normally' open momentary switch?
          yup
