Pentium M/Celeron M Vs Celeron/Celeron D
  • Pentium M/Celeron M Vs Celeron/Celeron D
    Which would you recommend? Thinking about things like power/heat, cost, and performance. Or would you just skip them all and get a Via C3 based board?
    Pentium M, definitely.
    The P-M will outperform a Celeron and it's designed for low-power applications, such as laptops.
    How about the Wiki?
      i chose celeron M, as its just as quick as a pentium M, although it has less cache and no speedstep technology (the ability to go into a deep sleep mode)... but other than that the Celeron M is on par with the Pentium M, and a hell of a lot cheaper.
      you cant compare a celeron M to a Pentium M in the same way you compare a Celeron to a P4... the celeron M is based on the exact same chip as a pentium M. Celeron and P4 arent.
      Read This....
      2005 Nissan Xtrail
      DFI 855GME-MGF - Celeron M 1.4GHz - 256Mb RAM - 200Gb SATA HDD - OPUS 150w - Xenarc 700TSV
      worklog
        Is the additional power savings and performance advantage of the Pentium M worth the cost over a Celeron M in a CarPC?
        Is this extra power (performance) really needed in a CarPC?
          Depends on how much you value your money. In my experience the difference is definitly notciable between equally clocked processors.
          StreetDeck.com Developer (I am Chuck)
          Get StreetDeck at http://www.streetdeck.com
          The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
            No and no.
            I have found you an argument; I am not obliged to find you an understanding.
              has your experience included pentium Ms and celeron Ms?
              a celeron M is not to a Pentium M what a Celeron is to a P4.
              2005 Nissan Xtrail
              worklog
                Well... someone has posted a place to get a Pentium M/Celeron M mobo for $200 shipped. Pickup a Celeron M for $100... for $300 you have something significantly faster than the Via sp1300 for only about $100 more. It also include wifi onboard and a miniPCI slot (use for bluetooth). Only thing missing is a PC Card slot.
                So the argument is really... is the extra performance of an intel chip over Via worth $100? If so... is it worth an extra $100 to get a little more performance and power saving with the Pentium M over the Celeron M?
                God of cpu... so there is a noticable difference in performance between a 1.3 Celeron M and a 1.4 Pentium M? As I mentioned above... it's worth $100?
                  yes
                  no
                  2005 Nissan Xtrail
                  worklog
                    Thanks!
                    Anyone else have something to chime in with?
                    Oh... what if you are building a quiet, low-power desktop? Pentium M? Celeron M? Pentium 4? VIA VT-310DP? Size target is something like Travla C137 or C138 sized case...
                      Sure they are. Celerons of a year or two ago were made from the Northwood core, just like the P4s of the time. The current Celeron D is made with the Prescott core, just like current P4s. The differences are parallel: reduced cache, lower bus speed, lower clock speed, and reduced features.
                      But that is only to nitpick. The point is still valid that a Celeron M is a much better compromise than the Celeron D. The downsides that make it a budget processor (reduced clock speed, reduced battery life) are less important outside of a notebook environment. Yes it will use a little more power, but still much less than any P4 Mobile. And you can't benefit from all of the P-M's power saving features in an environment where it will rarely idle, like in a CarPC that has to play music or display maps. If you all ready have to be prepared for a P-M's worst case power draw, then the fact that you use a few watts less most of the time isn't much of a benefit.
                        Thanks!
                        basics will still be the same, less power requires less active cooling (fans) and less noise.
                          Go with the Intel chips over the Via if you want performance. If you want to save a few bucks but want a bit more speed, go Celeron M, if you want true performance and speed, go with the Pentium M. Celeron M comes in clock speeds of 1.2GHz to 1.6GHz, with caches ranging from 512KB to 1MB all with FSB's of 400MHz. The Pentium M comes in clock speeds of 1.5GHz to 2.26GHz, with caches from 1MB to 2MB, and FSB's at 400MHz or 533MHz. If you compare the numbers, the Celeron M is slower than the Pentium M. And if you have ever used a Celeron based CPU and a Pentium based CPU, then you already know that the Celeron is slower. I'm using a Pentium M 730, 1.6GHz, 533MHz FSB, 2MB Cache on an I-Base MB896F board with 1GB Ram, this thing runs every bit as fast as my 3GHz 1GB Pentium 4 based desktop.
                          So the real question has already been asked...How much do you value your money? If you have spare change and you want top of the line, get a Pentium M. Get it right the first time, tends to save money in the long run.
                          Also, you said you were building a "quiet, low power desktop" You can easily achieve that with a Pentium 4 system, which usually tends to be cheaper than trying to build a Pentium M based desktop. Plus parts are more abundant.
                          Don't hold your farts in! They travel up your spine, into your brain, and that's where you get crappy ideas from!!!
                            I own a celeron M 1.6ghz, Pentium M 1.4ghz and a Pentium M 1.7ghz all on micro atx setups. Personally i notice quite a bit of difference between the celeron M and pentium M. The celeron is slower that the Pentium M 1.4ghz and no where close to the speed of the 1.7ghz. If money is an issue i suggest you get the pentium M chip from ebay. I got all my chips for ebay for pretty cheap. The 1.4ghz cost me $25 shipped and the 1.7ghz 533 with 2mb of cache cost me me $101 shipped. Here is a link to a few currently on ebay, but be carefull cause some people list the Pentium 4 m as the Pentium M
                              Originally posted by Kalt
                              ...If money is an issue i suggest you get the pentium M chip from ebay. I got all my chips for ebay for pretty cheap. The 1.4ghz cost me $25 shipped and the 1.7ghz 533 with 2mb of cache cost me me $101 shipped...
                              I second that...I bought my Pentium M 730, 1.6GHz, 533MHz FSB, 2MB cache, from Ebay for $107, shipped to me on the other side of the world. I think this same CPU retails for +/- $200.
                              Ebay...what would we do without it!
