USB Sound Card muted upon resume from hibernate
  • USB Sound Card muted upon resume from hibernate
    By searching the forums I know that I am not the only one with this problem. I have an external Sound Blaster Live! 24 Bit External sound card (sounds much better than the onboard sound on the M10000). Each time I resume from hibernation it is muted. Anyone know of a solution for this? I thought about using Frodo's setvolume app to unmute upon resume, but does anyone know why it mutes in the first place? I'll buy you a beer if you can help.
    I am reviving this post, casue I got the same problem. Did anyone ever figure this one out?>
      reviving....
      Was this issue ever resolved. I get the muted after resuming problem and sometimes the card will hang in a way that the only way to make it work again is by unplugging the usb cable. Not even a restart makes it work. Somehow unplugging the usb cable, even with the equipment off, resets something internally. This is a major PITA as the sound car and cables are all tucked away under the dash behind the center console.
        Well here I am digging this up to the surface. I had a VIA M10000 and never had this issue, but on my new board, KINO-690S1 I do. Infact if you try to go to any of the sound controls when this happens, you will get a pop up that there is no sound card connected, it doesnt mute, but completely is shut off or the creative software thinks it is. The only thing that I can think of that was diffrent is that I had a NEC 5 port USB 2.0 card connected. I can not recall if I had the sound card plugged into that, and thats why I didnt have the issue. I opened a ticket with creative labs, lets see what they say. Maybe there is a diffrent way that mini-itx power up and down there USB ports? or some feature that most USB ports dont have. It could also be the other way, maybe there is a feature that most MoBo do have that our MoBos are missung.... I will post the email upon arrival..... lets keep our fingures crossed. I have also ordered a extension ribbon so I can reconnect the PCI NEC USB 2.0 card.... I'll also post those results...
        1X Ainol Novo Flame Tab
        4X MK808b
        3x Perixx Touchpads
        3x 7 inch Screens
        1X 7 inch motorized Screen
        1x Win 7 PC
          Dear HiJack
          Thank you for contacting us at Creative Support Service, I am glad to be
          able to provide my assistance to you.
          I understand that you are having the issue of Live! 24-Bit external
          soundcard installed and PC will come out of hibernation mode.
          I would like to apologize for any inconveniences this issue on the
          soundcard is causing you. Let me see what I can do to assist you in
          resolving the issue you facing.
          You would like to uninstall the driver and applications completely to
          make sure there is no conflicts between the driver and your operating
          system. To do this, please run Clean sweep by following the steps below:
          Uninstalling Sound Blaster Drivers and Applications
          You might want to refer to the link for the correct procedure to install
          Soundcard to your PC.
          KB:Installing Sound Blaster Drivers and Applications
          I would also need you to provide us your system information in order for
          us to assist you further.
          Please follow the steps given below to capture the information and send
          to us.
          1. Install the System Information tool on your computer by referring to
          our Knowledge Base at the following address.
          [What is the Creative System Information tool?]
          2. With the XXX connected, click Start --> Programs --> Creative -->
          3. Click Save, take note of where the file will be saved and click OK
          4. Exit the program.
          5. Attach it to this email that you are replying
          Once again, thank you for contacting us.
          Best Regards,
          Steven
          Technical Support
          Creative Labs Americas
          I guess im going to go head and try what they tell me too..... Ive also went into the BIOS and turned off USB Legacy mode....... I want to see if that gets rid of the issue.
          PS: Links removed, they lead to inferior software. The ones on installation CD are better.
          4X MK808b
          3x Perixx Touchpads
          3x 7 inch Screens
          1x Win 7 PC
            Ok, turning off the USB Legacy worked for me, I have restarted several times and no issues..... there is also a more recent driver. The one we have, if installed from the disk is version 1.0.00, they linked me to a 1.0.03.
            4X MK808b
            3x Perixx Touchpads
            3x 7 inch Screens
            1x Win 7 PC
              I'll disable legacy support on the BIOS too. I just hope it doesn't disable the usb keyboard during POST.
              Can you put the link for the newest drivers?
                of course its going to disable your USB support duing POST, that the purpose of it HEHE...... I guess in order to have the SB work correctly we have to give up something. In my case my USB keyboards (PS3 wireless keyboards) dont have the del key to get into the BIOS so it doesnt matter to me. If you want your USB keyboard to work, you can always buy a USB to PS/2 adapter. That is what my keyboard for trouble shooting has.
                PS: Do not install any of the links I posted from SB, they are inferior to the ones provided on the installation CD.
                Also can someone maybe burn a image of the CD and upload so I can download? I scratched mine bad and is unreadable.
                4X MK808b
                3x Perixx Touchpads
                3x 7 inch Screens
                1x Win 7 PC
                  Very good suggestion but in my case the carputer is an ultra portable laptop and it doesnt have PS2 ports.
                  Getting into the BIOS is not that big of a problem as its not needed very often. The only time I really needed the keybord was once when an hibernation attemp failed ( powered it off during restore) so when the computer retarted it gave a menu where you could select to
                  delete restoration data and continue with system restart
                  or
                  reattempt restore operation
                  The funny thins is that there was no count down where the default operation would get selected automatically. Restarting the computer always returned to the same menu. I didnt have a keyboard on the car so I had to wait till getting home to plug a keyborad and press the ENTER key. Not having USB legacy support would mean that I would need to take out the laptop and press the ENTER on the laptop keyboard
                    or
                    that is a good point..... I didnt think of that one. Only thing I could suggest is get your system as stable so you wont get to the screen. I have never had to see that screen.... darn now you got me worried...
                    4X MK808b
                    3x Perixx Touchpads
                    3x 7 inch Screens
                    1x Win 7 PC
                      For the USB card issue I had a plan B. Since the only way to make it work again was by unplugging it from the usb port, I was thinking of using an usb extension cable and then route the usb cables in a way that the connection between the extension and the sound card cable was accessible from the arm rest compartment. If the card "crashed", I will just unplug the card cable from the extension and then plug it again.
                        I don't like that idea...... I think it should work as it should... if our mobos didn't try to access usb first I think the issue would be ok..... like my mobo BIOS thinks the sound blaster is a hub... which I think is the issue with me....
                        4X MK808b
                        3x Perixx Touchpads
                        3x 7 inch Screens
                        1x Win 7 PC
                          Well today I ordered my replacement CD.... cost me $10.34 with shipping included. Sucks that they dont have a downloadable version of the CD.
                          4X MK808b
                          3x Perixx Touchpads
                          3x 7 inch Screens
                          1x Win 7 PC
                            Try using this: http://support.microsoft.com/kb/311272 after resuming (deconnect, reconnect of devices in software).
                            Good luck!
                            List of front-ends/usefull apps
                            XTroniC | XTroniC Direct
                              Good luck!
                              BROOOOOOOOOOOOOOOOOOOOOOOOOOO, thank you, you pointed me in the right direction... i found this guys, explains in detail how to set up DevCon and a program called hibernate trigger.... You can set it up to restart a specific USB device...
                              http://thegreenbutton.com/forums/thread/170896.aspx
                              http://www.dti.nu/usb/
                              4X MK808b
                              3x Perixx Touchpads
                              3x 7 inch Screens
                              1x Win 7 PC
