Manual Power-On CarPC setup Diagram!
  • Manual Power-On CarPC setup Diagram!
    Hey guys, what do you think of my setup?
    This is a manual turn on/off carpc setup.
    Click image for larger version
    I was hoping tho, that someone would help me with the thickness of the wires from the distro-blocks to the relay, amps, etc.
    I've calculated my carpc power consumption and it apparently will have a peak of 200W. The carpcstore calc says that the minimum continuous rms power should be half of the peak.does this mean i would be ok with just a 150w psu?
    Anyone have any other suggestions?
    thanks!
    MSI KM4M-V Mobo -- AMD Athlon XP-M 1900+ -- 512MB DDR RAM -- LinITX 7" Touchscreen -- Seagate 8.4GB HDD -- LG DVDRW -- Onboard Graphics Card -- Onboard 5.1 surround sound -- Bluetooth Dongle -- RoyalTek Saphire GPS -- M2-ATX psu
    Why don't you lose the inverter and relays and crap and get an Opus 150w DC PSU?
    Then you get the benefit of not having to press a button to have the PC come on.
    How about the Wiki?
      for 2 reasons.
      1) its more expensive
      2) i want it to be manual for now. I can upgrade to auto-power later on if i want to.
      Can you answer my first post?
      Thanks!
        Only if I can read what the hell on the diagram.
        Seriously, if you thinking about saving money, go with DC-DV PSU. In the long run, you will be glad you spend more to begin with. I did use inverter for 6 months before switch to DC-DC. It took me that long cuz that is how long it took me to build the Sproggy.
        Manual control or automatic is just a mater of putting a ON/OFF switch between car's ACC and the PSU/Inverter remote turn on wire.
        Y2K Accord Dell GX150
        EmoRebellion is a SCAMMER
          LOL is it really that bad??
          coudnt upload better quality pic, only had 200k max size.
          can u read it at all?
            wot about wire thickness? 8 gauge?
            how big shud the fuses be?25 amp correct?
            finally the psu, will i have enough with a 150w psu?
            thanks.
              The Opus 150w should power that setup with no problems. It's pretty comparable to my setup... I have the 35w version of the Athlon XP-M 2400+ in a Shuttle SN41G2.
              Also, the Opus 150w isn't the only DC-DC power supply. There are DC-DC ATX power supplies that will give you up to 250w... Not all have the bells and whisltes like shutdown controller, crank survival, battery saving, etc., so read specs carefully.
              Some other choices: M2-ATX (rated at 160w), DSATX (rated at 220w), KeyPower (rated at 250w)
              I'm likely going to use the DSATX for it's smaller size and higher power rating, so that I can upgrade the PC later on or add more devices as I wish.
              How about the Wiki?
                i know dude :S
                Opus looks great but its way out of my budget $160 is a lot of money plus the postage and packaging cost to europe!!
                What can i do?
                  Originally posted by ironic
                  i know dude :S
                  What can i do?
                  Buy a M2-ATX from www.cartft.com
                    Audio: 4 * Rainbow Audio Germs + Infinity Basslink / Case: iStarUSA S3 / CPU: C2D P8700 / MB: Jetway NC64-LF / SC: ASUS Xonar Essence STX / RAM: Crucial 2x1GB 1066MHz / HD: MTRON 2.5" 30GB / DVD: Panasonic UJ-815B / PSU: Opus 180w / LCD: Xenarc 700TSV
                      Get M2-ATX and 5V POL for drives and you are set.
                        wots a 5V POL???
                          5volt point-of-load.
                          How about the Wiki?
