Solid State HD!
  • Solid State HD!
    http://www.memtech.com/index.html
    This site had our answer, atleast for an OS drive. I cannot find a price but the solution is there.
    Last time I asked them for a quote, which I'll admit was a couple years ago, the drives were not for consumers and were running $15-$20k. They told me they were solely for military applications, with no consumer plan for the short term. There's a reason they don't quote a price on their site
    Intel Pentium M 1.6GHz (Dothan)
    MB896 Mobo
    1GB Ram
    Lilliput 7" Touch Screen
      Solid state? Sounds like all other hard drives are powered by tubes
      Progress - VIA EPIA SP8000 | 120 Opus Power Supply & Case | 1GB Ram | 120GB 2.5" Hard Drive | Bluetooth 2.0 | GPRS/3G | Wifi | Road Runner/LSX 2.0 (waiting for a day skin for 3.0) | iGuidance 4.0 | Lilliput 7"
        Gives overdrive a new meaning in cars...
        (I drive stick though)
          These are going to be uber-expensive.
          They don't sell to consumers, but distributors of custom projects, like industrial computers and the like.
          How about the Wiki?
            Whats wrong with CF card connected to IDE trough CF/IDE adaptor???
            Cheap, fast enough and reliable.
              fast enough? not really... plus you'll exceed the maximum number of rewrites eventually too
              MB896 Mobo
              1GB Ram
                ummm..no. you use EWF on any flash media to protect it from writes
                EWF, HORM, MinLogon on XP.
                Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
                Win Embedded Std 2011 RC
                OCZ Vertex Turbo 30GB SSD
                Lilliput 629 Transflective, WRX Screen Mount
                BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
                VoomPC 2
                  That company even makes ejection seat hard drives. That survive 2000G's.
                    Sure you can run EWF, but doesn't this basically make the CF a static image? So you could be booting off a CD then if you really wanted to, and you don't get a swap drive or any write capability.
                    MB896 Mobo
                    1GB Ram
                      ah, guitar and nerd humor comes together. awesome
                        The drives you have posted are flash drives too. Same technology, same limitations, and most likely same level of read/write data transfers.
                        There are a cards that can do true 20 MBps and they are not expensive at all. On the other hands, fastest harddrives are badged ATA133, meaning they IDE interface can do 133 MBps, but due to physical limitations of drive mechanics they do about 35 MBps. Where is the difference?
                        TwinMOS 140x 1GB is beeing sold for some 59USD.
                        What else would you want??
                          You can make it so only the info you need is written to the disk. Also...a fast 2GB USB flash stick costs about $125...
                          VoomPC 2
