Any1 done this? Radio Faceplate Mod
  • Any1 done this? Radio Faceplate Mod
    I'm putting my faceplate seperate from my radio housing, i ran the cables and got everything to work but i cant eject the cd. I think it's because it thinks the face is attached and covering the opening, anyone know the trick to make it work? I solder all the wires to the connectors
    Theres might be some kind kill switch that the face plate opens when its down, inorder to eject the cd. On other models, when the face plate opens, it breaks the connection (terminals) between the face plate and the head unit, if this is the case, then you need to find a way to kill the connection between the two inorder to eject your cd...
    just my 2 cents
    http://www.sounddomain.com/ride/856246
    Please visit my new site http://www.Gigabitcustoms.com
    My worklog http://www.mp3car.com/vbulletin/showthread.php?t=52720
      GigaS27,
      What brand and model of radio do you have?
      8" Lilli TS
      MB896F Mini-ITX MB
      2GHZ Dothan 533MHz FSB CPU
      1GB SDRAM DDR2 533
      Seagate 300GB SATA150 HD
      ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
      Pioneer Slot Load SLIM DVDRW
      Bluetooth V2 USB 2 Dongle
      3COM BKP Cam
        when the face opened stock, did the faceplate maintain the connections, or did it tilt away from the plug& disconect when opened?
          Hey guys thanks for the replys. I have a Pioneer DEH-7600MP. I finally got it to eject. BAsicly their was only one wire that i needed to add a switch too so it can eject the cds. IF you guys wanna know for the future on this model if you looking at the radio its the 2nd connector from the left to right on the bottom.
            http://www.mp3car.com/vbulletin/showthread.php?t=22819
            Pics included...Did it two years ago.
            SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
            GPSing - Digital Speedo
            Relocating headunit and extending faceplate
            Button app to Alt-Tab between two programs
