Lengthening IDE cable questions
  • Lengthening IDE cable questions
    I am trying to locate an XBox DVD drive to my dash, but in order to do that I need to extend the IDE cable. I bought a few 1 foot extensions just because they were cheap so I could test it out. I put one on at a time until it didn't work. I extended it 2 feet and it worked fine. When I put the third foot on there, it recognized the drive and the disc, but would not load. I need that third foot, plus another 6-12 inches.
    My question is, if I bought a cable that was continuous, would this be better than having a bunch of little one-footers connected. I would think you may lose a little something with all of those connectors. Also, this is only a 40 pin cable. Can I use an 80 pin? Will it plug right in? From what I've read, the 80 pin has a ground wire between each of the 40 to produce a cleaner signal. My thoughts are, if I have a continuous 80 pin wire, I just may be able to get the 3 and a half to 4 feet I'm looking for if 2ft worked fine the way I had it rigged up. I just wanted to see your thoughts, since I don't have any experience with this. I don't know how much of a difference being continuous and having 80 pin wire vs. the 40 pin would help. If anyone has any experience with this, I'd appreciate any thoughts, ideas, or help.
    Thanks alot.
    IDE specification is for max cable length is eighteen inches.
    Twenty-four inches is relatively common, but technically outside the official IDE specifications.
    Any longer than that and I wouldn't count on it working, plain and simple.
    Considering that Xbox uses some proprietary disc format that's not CD or DVD, the likelihood that using a connection out of spec will work is even less. You've been given this information before, but you don't seem to think it's worthwhile or are just plain ignoring it.
    You need to come up with a new plan. Sorry if you don't like that, but it's fact.
    How about the Wiki?
      I've seen some hacks that let you do real USB on the x-box; one of those coupled with an IDE-USB adapter for the DVD *might* do the trick. At the hardware level it should certainly work, at least, but it is questionable whether the x-box software would talk to a USB drive.
      -g.
        Do your research.
        Maybe also I should change my sig to add 15 foot IDE 80wire to my list of things I've used for 4 years.
        I have a 15 foot IDE 80 wire powering my dvd-cdrw laptop slotload in my glovebox.
        You cannot buy 80wire IDE extension cables Male and Female connector from www.Stonewallcable.com.
        But you can buy a 40wire one, but it won't work.
        Replace the whole IDE with a continious 80 wire 40 pin and it will work. You can get it from www.stonewallcable.com
        http://www.stonewallcable.com/produc...++++++++++++++
        $21.00 + $0.05 per Inch
        This cable isn't for show and it plain works, and that's a fact!
        SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
        GPSing - Digital Speedo
        Relocating headunit and extending faceplate
        Button app to Alt-Tab between two programs
          Look...
          I'm not saying anything bad about your setup. I'm glad you've got this long-as-hell IDE cable working.
          Look at what I told the OP:
          The official IDE specification sets a maximum cable length of eighteen inches.
          Two-foot IDE cables are very common, although technically out of specification.
          I wouldn't count on it working with a longer cable.
          My research isn'g going to go into any number of people that have longer-than-spec (or longer-than-common-length) IDE cables. Your'e not the only one who has a long IDE cable that works.
          There are also many others who have made such a cable that haven't had your results, too. Yours is a special case.
          Kudos for you. You beat the odds. You bucked the system.
          But telling someone that a 15-foot cable will definitely work, especially in a non-standard setup like an Xbox is false. You don't know that it will work, but you believe it will.
          Hell, even your cable source won't guarantee a cable longer than four feet:
          Originally posted by stonewallcable.com
          Note: This 40 pin, 80 conductor ATA ribbon cable allows for custom placement of the connectors on the cable. Configuration is blue (controller), and black (primary drive). Our ATA cables are guaranteed to a maximum length of 48 inches. The length, in inches, is the distance between the two connectors and not a tip to tip measurement.
          So is it worth a shot for osnola22 to contact this vendor? Sure. I'd say it's worth a shot, but I'd call them and ask some questions about the use of the cable in an Xbox before dropping $30 or so on a cable.
          How about the Wiki?
            Can't he just return it if it doesn't work?
            You never know till you try!
              Most suppliers won't take returns on custom-made pieces.
              Of course, you could always ask.
              How about the Wiki?
                if the wires are twisted it might work
                Via SP-1300, 512 MB, M1-ATX, 7" Liliput, DBT-120, 80 Gig 2.5" 5400 RPM HD, Ericsson T616, USB SB Live 5.1 sound card, XP Pro SP2, RoadRunner, Slim DVD -R/+R, XM Direct, and GPS/Map Monkey.
                  I just got my 18ft 80/40 IDE from stonewall cable and it does NOT work. May be its because there are 2 drives hooked on it. But we dont have a second IDE port in the xbox. Its weird because the DVD boots up if theres a game in it but the HDD doesnt even though the cable is setup as
                  HDD <---- 24"----> Controller port <---- 16ft ----> DVD
                  Controller Port <---- 24"----> HDD <---- 16ft ----> DVD
                  I expected the HDD to boot up and not the DVD rom. The cable costed my $50 after shipping so I dont think im gonna trial and error another one.
                    My 15 foot IDE only has 1 connector on it. Maybe the reason...
                      Could be. The guy at stone wall called me and asked if it was a typeo when I was ordering the cable since he said that he thought it was 21" not 216". But yeh the 2 drives could be the reason, but again on the xbox we only have a IDE0 so there has to be a master/slave config. The made my own 15ft extension of the yellow cable and it allowed tray functions. Also the length is WWWWWAAAAYYYYY out of the IDE spec so it was 50-50 shot on it working. I have a 6 cd changer in the car, I can suffice with the dvd rom sitting in the trunk. Im gonna talk to my professor and see if he has any other creative inputs.
                      Another possible option would be to go IDE -> USB -------- USB -> IDE but the only cables out go from IDE to USB.
                        but going via USB is slower than going directly via IDE usually. depends what you're using it for I guess, and how hogged up the USB bus is.
                        Current:
                        [BMW E46 ///M3 Convertible]
                        Previous:
                        [BMW E31 850CSi]|[BMW E39 535i]|[BMW HVAC Research]|[IBUS Scrolling Text]|[BMPuter]|[Velocity]|[TomTom]|[Vision]|[Space Navigator Driver]|[Super Fast Boot]
