weird power/reset switch problem
  • weird power/reset switch problem
    I have an M1-atx with a SP13000.
    When opperated just by the acc wire for the shutdown/start up controller on the M1, it works fine. And I can shut it down by pressing the power button hooked up to the M1 or to the MoBo. BUT, the power button will not turn the comp back on after it is shut down until I disconnect and reconnect the Acc power. and the reset button does not work at all. I am sure I have the correct wires hooked to the right jumpers on the board.
    Any other suggestions?
    Causa latet vis est notissima
    VIA SP13000
    1GB DDR400
    Slimline Slot-load DVD-RW
    60GB 2.5 Inch SATA 5400RPM
    Dual Active PCI riser
    PCI TV/FM card
    Logisys FP800
    Thermaltake VFD Media Lab
    M1-ATX
    hmmmmm
    VIA SP13000
    1GB DDR400
    PCI TV/FM card
    Logisys FP800
    M1-ATX
