How loud is too loud for a Carputer?
  • How loud is too loud for a Carputer?
    Quick question, what do you guys think an acceptable dB level is? I'm not talking about music....just having the system on w/ fans.
    I found a fan that has less than 20dB and it will be in my dash. Ya think that might be too loud? what could I compare that to so I could actually hear something @ 20dB?
    Thanks,
    Amit
    Progress: -10%
    I had a couple of vantec stealth fans, which are rated at like 21dB. They were pretty quiet. I don't think you'll get a good idea of how loud a fan is going to be unless you listen to some similar fans in person. Of course, if you add a speed control to it you can easily turn it to whatever speed makes it "quiet enough" for your application. With any amount of road noise, I don't think you'll really be bothered by the noise of a 20-21dB case fan, and probably not hear it at all.
    But don't take it from me! here's a quote from a real, live newbie:
    Originally posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
      What do you think of these?
      http://www.newegg.com/Product/Produc...82E16835118212
      20 dB
      http://www.newegg.com/Product/Produc...82E16811999144
      16 dB
      Progress: -10%
        i dont hear the 92 mm fan in my console unless i have the engine off. its rated at just over 30 i think.
        60db is about normal conversation
        1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
        Pictures
        Photobucket is being updated, if a picture i posted no longer works, please PM me.
          Originally posted by ComputerDoctors
          The zalman's quote is over-ambitious, don't let the numbers fool you, it's really freaking loud, so much so that it makes my head hurt. TT is also known for fooling with their numbers, but with a 130mm fan, you really get away from that annoying pitch that little fans have. According to the review on that page, there is some "annoying humming", some people prefer the hum over the whining, I prefer the sound of my own thoughts, opposed to any sound from a fan, so ymmv
          1995 Ford Mustang Convertible
          DSATX | Shuttle XPC SN41G2Bv2 | 619GL-70NP | CF 1.6 (which is still unusable in the car!)
            I know...the Zalman SAYS its 20 dB in quiet mode...so that is something to look at
            and the TT is a big fan...
            Progress: -10%
              Don't worry about ratings, get a fan that is known to be quiet and you'll be all set.
              Panaflo's M1A and L1A lines are DEAD silent, regardless of raiting, and their H1A's are high performance (aka.. loud) but can be trimmed properly with voltage reduction (7v H1A = M1A)
                It is my opinion that if I can hear it while sitting in the car with the engine off, it's too loud.
                  Definately stay away from the zalman, it's nothing more than a gimmick, if you are looking for fans that are quite, you're going to want to buy Panaflo's!
                    Here's where I usually pick up my panny's:
                    http://www.jab-tech.com/Panasonic-Panaflo-c-220.html
                    Remember, keep away from the H-series if you want to keep quiet
                    L1A's are DEAD silent, M1A's are pretty quiet but you can make them dead silent with voltage regulation, and H1A's are pretty loud
                      Are L1A's really that quiet? I have a cheap generic fan:
                      http://www.mdmm.com/spec.php?productid=88
                      But they are rated at 24 DB. The 120 mm L1A is rated at 30 DB. I want to make the carpc quieter because the fan is driving me nuts...the PC is no where near quiet. But I can't tell if it is the fan making all the noise or if it is the wind bouncing around in the case that is making all the noise. Would it be wise to pick up a panaflo? or stick with what I have?
