Slimline dvd to... usb?
  • Slimline dvd to... usb?
    Hi all,
    I purchased a Pioneer Slot Load DVR-K05 (slimline laptop dvdrom) with the intent of mounting it in my dash and connecting it to my pc which is basically under my drivers seat. (3' away or so).
    I have seen (and purchased) the slimline -> IDE adapter that allows me to put it on my ide chain, however finding a 3' ide cable + power is not a good or even viable answer. Along those lines I also saw and purchased an IDE -> USB adapter, however this is also a large adapter making the slimline dvdr not so slimline. Oh, and it doesn't work when I try to connect it that way (too many conversions?).
    Does anyone have any hardware suggestions for what I am trying to do? Preferably, I'd love to use the existing dvdr that I already spent $100 on, but if that isn't possible, I can accept that.
    Thanks as always, you all rule!
    03 Dodge Ram 1500 QuadCab
    Epia SP 1Ghz cpu, 512mb ram, 40gb 5400rpm hdd, 60gb IPOD
    Xenarc 10" touchscreen
    SIR-ALP1, Opus 150w PSU, Griffin Powermate knob
    RoadRunner, LSX Void 800x600 | iGuidance 3.0
    Zyxel P-330W for borrowing wifi
    did you connect the ide>usb adapter and also give it power? it doesn't carry its own power through the adapter so you'll have to get the 5v from your psu
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
      http://www.customcarcomputers.co.uk/...3ee0bba73747b2
      something like that might suit you need better
        [email protected]#[email protected][email protected][email protected]# that's perfect!!
        Once again, problem solved via these forums. You rule
          Here's another. I just got this one and am using it via firewire. No extra power wire needed. It works with USB as well but you must give it 5V separate.
          http://www.logicsupply.com/product_i...roducts_id/422
          ~Jimmy
