sp13000 help
  • sp13000 help
    i just upgraded my m10000 to sp13000. I set everything up and booted it up and im not getting in video. the fan starts going but the moniter stays blank. any ideas
    Did you buy it new? Should work out of the box.
    I have nearly the same mobo and I made a mistake during initial setup that kept it from outputing any video. I was tweaking the display settings in the CMOS RAM and I chose LCD instead of CRT. That doesn't work unless you have something connected to the LVDS video port (for LCD's). Zenarc is standard VGA even though it is an LCD screen. I had to reset the CMOS RAM to fix it. It is easy to do, the manual tells how. It is worth a try before you return the board.
    ~Jimmy
