DDR2 SDRAM Question
  • DDR2 SDRAM Question
    Would 2x1GB Memory modules draw more power from the power supply than 2x512GB?
    And what about start up time difference/hybernation.
    http://incarCPU.com
    AFAIK, the amount of memory on the stick does not change power consumption.
    Hibernation would take FOREVER with 2 gigs... I stick to 512 because of this. 512 for me takes about 12 seconds to hibernate. Coming out of hibernation, it's only about 8 though.
    2 sticks of DDR2 will take up about 15 watts total.
    Tidder
    Try RevFE
      What about 2x512 vs 1x1GB?
      Which setup do u think is better (for power consumption and boot/hyber/sleep times)?
      http://incarCPU.com
        Power consumption, less is always better. If your board supports dual channel, I'd go with the 2x512, just a little more performance. If not, stick with one stick. Hibernation won't change either way AFAIK. It'll still take FOREVER.
        Tidder
        Try RevFE
          Wat psu are going to use? If you want fast n cheap go with http://www.zipzoomfly.com/jsp/Produc...e=85201&ps=ho1
          "Banking establishments are more dangerous than standing armies." Thomas Jefferson
            I need PC-4200 533Mhz DDR2 dual channel. Thanks for the link though. That store has some cheap memory.
            "Kit" doesn't mean its Dual-Channel or does it?
            http://incarCPU.com
              Kit means its a matched pair made of the same batch. Yes the ram supports dual channel since on top of the page it says
              OCZ OCZ4002048ELDCPE-K 2GB Kit DDR400 PC3200 Platinum Edition Dual Channel Memory Retail
