External DVDRW
  • External DVDRW
    i have an external DVDRW and it has an adapter with it, from 240v AC to 12V DC, will i just be able to plug a 12v direct from by battery into it, obviously running through a fuse?
    Neither. A regulated 12v power source is what you need.
    How about the Wiki?
      i will have to put an invertor in then
        Not necessarily. There are other power regulators out there.
        Look in the store here for Carnetix units.
        How about the Wiki?
          could i just run it from my opus150? make a big lead from the rear of the car t the front?
            Assuming you've got unused power output from the Opus, certainly you could.
            Remember that the Opus 150w only provides 5a on the 12v rail.
            How about the Wiki?
              i am scrapping my CDRW in the pc and just powering this, when i do it, can i just make a lead up using the 12v wire from the opus and then any earth? or does it need to be all 4 wires?
                yeh it is 12v, i have just tried it using the IDE cables and power supply and my opus can cope with it i didnt try burning though, but did try playing a dvd.
                I tried it with the USB but it didnt work,
