Shuttle sv24 or fv24
  • Shuttle sv24 or fv24
    I have a shuttle sv24 and i was woundering if i could put an
    Intel P3 FC-PGA2 Tualatin 1.266ghz 512k (not 256k) cache processor
    I have a celeron and plll 800mhz and they run fine, my board is a socket 370 and the cpu is the same.
    It is a mini itx sort of, just a little bigger and i wanted to know if my board could handle this cpu, this would be one hell of a carputer if i could get it to work, i havent bought the cpu yet waiting to see if it would work.
    I tried it and it wouldn't post, with the same cpu.
    Setup:
    Dynaudio 240GT
    PPI PC4100, PPI PC2350
    Zapco DSP6
    ADS DAC
    Testing new board (Albatron KI690-AM2)
    "I dont know if complaints were filed, or mistakes were made, but feelings were hurt." -Krystal Washington
      Shuttle is its own formfactor, for what its worth.
      The manual can be found here: http://ftp.shuttle.com/Manuals/en/sv24/fv24en.zip
      I don't think you'll bave any problems with that CPU, although I suggest updating the BIOS for the FV24 to the latest version. It will increase the likelihood of your proposed mobo/CPU combination working.
      Shuttles rock.
      [EDIT]
      ****. A minute late.
      Well, maybe it won't work.
      proph: You gonna be at Hooters Sunday?
      How about the Wiki?
        Shuttles rock.
        [EDIT]
        Actually, the Tualatian (what ever it is) WILL NOT WORK in the shuttle board.
        Michael
        http://www.badcaps.net/forum/showpos...43&postcount=4
        and
        http://www.badcaps.net/forum/showpos...33&postcount=6
          Isn't that what I said... well anyway. Don't let a good topic go to waste. Any other good info for these boards. Hmm... adding a mic you'd have to get the connection from inside the pc since theres only a line in and line out on the i/o panel.
          The board with a p3 800 is faster than an Epia 800 w/ the same core (I have both).
          Is there a way of adding a boot logo to a board that doesn't come w/ one? My bios is a bit slow and I'd rather see a custom logo or something. Is it possible?
          Setup:
          Dynaudio 240GT
          Zapco DSP6
          ADS DAC
            the FV25 will handle that CPU... it was a little later in the production run.
            TruckinMP3
            Read the FAQ!
              Well guys I had a celeron in it 800mhz and it sucked choppy playback for videos and unresponsive alot, changed it to Plll 800mhz and it was night to day, play back for movies is awsome, road runner runs fine and no freezing, also boot time has decreased.
              I still want to purchase a 1.26 or 1.13 tual. but i read the manual
              http://global.shuttle.com/Support/Su...r=SV24%20(FV24
              this is my new one
              133MHz 6x Intel Pentium III FC-PGA 800EB MHz
              Intel P3 FC-PGA2 Tualatin 1.266ghz is a FC-PGA2 only supports FC-PGA
              only supports these
              FSB Multiplier Processor
              100MHz 7x VIA Cyrix III 700 MHz
              133MHz 4.5x VIA Cyrix III 600 MHz
              100MHz 6x VIA Cyrix III 600 MHz
              100MHz 5.5x VIA Cyrix III 550 MHz
              133MHz 4x VIA Cyrix III 533 MHz
              100MHz 5x VIA Cyrix III 500 MHz
              133MHz 7x Intel Pentium III FC-PGA 933 MHz
              100MHz 9x Intel Pentium III FC-PGA 900 MHz
              133MHz 6.5x Intel Pentium III FC-PGA 866 MHz
              100MHz 8.5x Intel Pentium III FC-PGA 850 MHz
              100MHz 8x Intel Pentium III FC-PGA 800 MHz
              100MHz 7.5x Intel Pentium III FC-PGA 750 MHz
              133MHz 5.5x Intel Pentium III FC-PGA 733 MHz
              100MHz 7x Intel Pentium III FC-PGA 700 MHz
              133MHz 5x Intel Pentium III FC-PGA 667 MHz
              100MHz 6.5x Intel Pentium III FC-PGA 650 MHz
              133MHz 4.5x Intel Pentium III FC-PGA 600EB MHz
              100MHz 6x Intel Pentium III FC-PGA 600 MHz
              100MHz 5.5x Intel Pentium III FC-PGA 550 MHz
              133MHz 4x Intel Pentium III FC-PGA 533EB MHz
              100MHz 5x Intel Pentium III FC-PGA 500E MHz
              133MHz 7.5x Intel Pentium III FC-PGA 1.00 GHz
              66MHz 8x Intel Celeron PPGA 533 MHz
              66MHz 7.5x Intel Celeron PPGA 500 MHz
              66MHz 7x Intel Celeron PPGA 466 MHz
              66MHz 6.5x Intel Celeron PPGA 433 MHz
              66MHz 6x Intel Celeron PPGA 400 MHz
              66MHz 5.5x Intel Celeron PPGA 366 MHz
              66MHz 5x Intel Celeron PPGA 333 MHz
              66MHz 4.5x Intel Celeron PPGA 300A MHz
              100MHz 10x Intel Celeron FC-PGA 1.00 GHz
              100MHz 9.5x Intel Celeron FC-PGA 950 MHz
              100MHz 9x Intel Celeron FC-PGA 900 MHz
              100MHz 8.5x Intel Celeron FC-PGA 850 MHz
              100MHz 8x Intel Celeron FC-PGA 800 MHz
              66MHz 11.5x Intel Celeron FC-PGA 766 MHz
              66MHz 11x Intel Celeron FC-PGA 733 MHz
              66MHz 10.5x Intel Celeron FC-PGA 700 MHz
              66MHz 10x Intel Celeron FC-PGA 667 MHz
              66MHz 9.5x Intel Celeron FC-PGA 633 MHz
              66MHz 9x Intel Celeron FC-PGA 600 MHz
              66MHz 8.5x Intel Celeron FC-PGA 566 MHz
              66MHz 8x Intel Celeron FC-PGA 533A MHz
              100MHz 11x Intel Celeron FC-PGA 1.10 GHz
