help powering m1000 without power switch
  • help powering m1000 without power switch
    hi just got my hands on a New Epia M1000 board but cant seem to power it up or wont power up, cpu fan doesnt startup or nothing ive put the PSU connecter in and switched on the power supply (this is at home not in car for testing purposes) but wont start up automatically as soon as theres power, ive got another epia m1000 board which does power up as soon as ive given it power without using any switches to switch it on, this one came like that, but the other board ive got wont startup, any one know how to configure this or maybe where im going wrong.
    Regards
    Amar
    anyone???
      Short pins 6 & 8 in the front panel connector to turn it on.
      How about the Wiki?
        The MB I have (not Epia) has a BIOS setting to boot when power is restored. By using this I do not have to use the switch. Check for something similar on your Epia after you get it started by using the instructions from DarquePervert (above)
        TruckinMP3
        Read the FAQ!
          thanks guys it worked, now whenever i do switch it off and leave it off than turn the power back on again it wont startup automatically have to jump start it manually with a screwdriver checked in the bois settings but couldnt find it would you know what it would be under i coudnt see it checked twice
          thanks
            Mine is under power management but I do not use an Epia board.
            TruckinMP3
            Read the FAQ!
