Need help - Soundcard onboard(no sound)
  • Need help - Soundcard onboard(no sound)
    Hi all..,
    I have an interesting problem. I have install a computer and work well with normal power supply. The problem is onboard sound. When i connect the computer to M2-atx on vehicle... the computer start well and everything work well, but no sound. I'v checked the system and see no sound detected.. , so i disconnect it and try again with normal 220v power supply and the sound works well(detected). after while, i am going back to try again on the vehicle.. and the result.. no sound again? very confused ..
    before, i use intenal audigy 2 zs works well on vehicle , but not with onboard sound. BTW, i'm using gigabyte ATX motherboard all in one.
    hope someone can solve this problem or give any idea to solve it..
    Thank you verymuch...
    Anyone can help??
      I am not sure but here is a shot to start.
      What is the different between M1 and AC PSU (regardless of wattage).
      Does the M1 has all negative (-) power rails (-5V, -12V)? It's probably doesn't has one of the 2 or both that the board is required. I think 1 of the neg power rail is obsolete thus not on M1 PSU.
      Hook up the AC PSU and M1 to check them out with a meter.
      Y2K Accord Dell GX150
      EmoRebellion is a SCAMMER
