Biscuit PCs Opinions Please!
  • Biscuit PCs Opinions Please!
    I'm currently looking at the Advantech Biscuit PC selection:
    http://www.advantech.com/products/pr...Biscuit%20SBCs
    Does anyone have any opinions on these 'mini-motherboards'. I'm looking at these as I already have a Sharp LQ10DS05 TFT Screen which has a 40-pin Hirose connector which is meant to be compatible directly with them. I figured that it was cheaper to buy a biscuit board rather than a controller and another portable solution.
    Some even have built in audio, network and compactflash. Plus, is it possible to use the PC/104 expansion for adding an ISA TV card? I thought I could use an adaptor like this - http://www.douglas.com/hardware/pcbs...cbde63104.html and a cheap card of ebay for full screen tv.
    Any suggestions or past experience would be much appreciated.
    Many Thanks,
    Alex O'Donnell
    I'm using a advantec 5820 for my setup and i have experience (due to my job) with several others. I can only recommend them.
    If you want to use an ISA adapter you have to make sure that the motherboard has an 16 bit PC/104 connector. (But I don't think that there are any boards with just 8 bit slots around anyway...)
    Also make sure that the LCD you want to connect is really supported by the board you want to buy. I've never connected a LCD directly to one of my systems, but I know that advantech sells special wiring kits for *every* type of LCD they sell.
    hope that helps
    jics
    ...Unix, DOS, and Windows XP
    (also known as the Good, the Bad, and the Ugly).
