my computer wont boot to windows, says "Boot From CD :"
  • my computer wont boot to windows, says "Boot From CD :"
    my computer suddenly has stopped booting all the way to windows... after in says "Building DMI Pool......" in the boot process, it then says "Boot From CD :" and does nothing.
    i have the sp13000 mobo... what could be wrong?
    carputer - done.
    this has happened once before, but when i unplugged the computer and plugged it in it worked fine again.
    i tried unplugging it and plugging it back in today, and the same exact thing happened, about 5 times.
    on the screen before it gets stuck, it recognizes both of my HDDs and my optical drive.
    carputer - done.
      do you have a CD in the drive? often some of my computers won't boot past that point if there is a CD in the drive that is not a bootable CD.
      But don't take it from me! here's a quote from a real, live newbie:
      Originally posted by Viscouse
      I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
      eegeek.net
        no, there hasnt been a cd in there in months (and i checked to make sure)
        carputer - done.
          whats the button to go into the bios setup to change the boot order? i dont see it displayed when mine boots up...
          carputer - done.
            Try either DEL or F2. Either one of those is use by most system.
            Y2K Accord Dell GX150
            EmoRebellion is a SCAMMER
              hopefully its F2, cuz my mini keyboard doesnt have a DEL
              i tried F8 already...
              carputer - done.
                It's DEL. F8 just gets you the Windows boot menu. You can always jack your desktop keyboard untill you get in to the BIOS.
                -ZtH01
                "It's my belief that my big balls should be held every night"
                  i guess thats what ill do... this better work
                  carputer - done.
                    if you're using the PS2 mini keyboard, I'm pretty sure it has a del key.. I believe you had to use the Fn modifier, though.
                    Dr. Ron Paul for President 2008
                    Hope for America - http://www.ronpaul2008.com
                    Who is Ron Paul? - Why do we need Ron Paul?
                    CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
                      if it does, its not labeled...
                      carputer - done.
                        sorry, i was thinking of the "backspace" key (symb + spacebar).. my bad.
                          problem solved -
                          after i changed the boot device order (for some reason USB FDD was #1, i would never have set it that way) to put 'Hard Drive' as #1 it still didnt work, but only said "Building DMI Pool" with a flashing cursor under it...
                          then i checked the Hard Drive boot priority, and for some reason they were also out of order, so i put my boot drive as #1, and then rebooted, and it worked
                          hope this helps in case anyone else has a similar problem...i dont know why it all got switched around...
                          carputer - done.
