Will this work?
  • Will this work?
    http://www.allelectronics.com/cgi-bi...396&type=store
    To use to control if my mp3 box is on?
    Yes.
      im curious and not much of a wiz with wiring and stuff like this was wondering how do you plan use this
      Case built and working
      Amptron 586 motherboard onboard snd/vid/lan (purchased)
      200mmx processor (already have)
      5g harddrive (already have)
      Two 4x40 lcds (future)
        Essentially, a relay allows you to use a small current to switch a much more powerful circuit on and off.
        Brian
          The only thing that bothers me is that id dosent give me spec. about how many volts i need to turn over the switch. I asume it will just be 12 volts.
          I'm going to order it, or the one that is a pc board desighn and we'll see how it works
            Your assumption is correct 12v dc is the require switching voltage. Don't for get a diode to prevent back emf.
            Rob
            And you say people actually pay money for M$ Windows?
            www.mp3mini.co.uk (Does what it says on the URL) www.openclassic.co.uk (The new car, with zero rust!) www.rob-web.co.uk (My other site)
            Total re-design underway: on the whole progress is very slow as the car is taking up too much time :)
              Check here for Full specs
              http://www.azettler.com/prod/az9711.htm
              They have a 6V part that pulls in @3.3V if you want to run it w/ 5V
              If you come out talking sh1t don't try to turn around and wipe you azz.
