Sbc....
This topic is closed.
  • Sbc....
    Ok it is time for my next box
    I might be going the SBC way this time. I want a SBC atleasta pIII 500+ mb
    1) It must have TV-OUT!!!!! a must!
    2) It must be capable of playing DVD's!!! another must!
    3) It must have USB
    4) DOC is ok, but not a must....
    5) It must have atleast 2 ide... HD + CDROM!!!! a must
    6) It must have onboard sound...
    7) Power....from what i see so far it looks like most take from 5/12v at diff amps so thats a diff story!
    8) Last but not least it MUST BE SMALL.
    9) oohh optional PCI....
    I hope i didnt miss anything... I need this info ASAP so i can start drawing things out
    abcd-1
    http://www.advantech.com/products/PCM-9572F.asp
    This one has everything you've stated, but it's not cheap. Direct from Advantech this if $870, includes on onboard P3-500 CPU.
      how did i miss that....what else is out there
      abcd-1
        Here is the one I would get....
        http://www.emacinc.com/pc_compatible...o/pcm6890b.htm
        It is $469.00 on this site but someone said you could buy it cheaper somewhere else...
        Still, $469 sounds like a great price for what it does!
        This will be my next car pc for sure!
        Mike
        1999 voyager pontoon boat
        (soon to be computerized)
          yikes...getting better...
          now can that one handle DVD????
          abcd-1
            I dont see any reason it wouldnt with the right chip (p3 800) and enough ram
              Hmmm....its either i am looking at the wrong board or something else. D/l the *.pdf file, it says it only support Celeron 300-444mhz
              abcd-1
                A more cost effective offering from Advantech would be the PCM-9574. At only $435, this sucker packs quite a punch.
                EDIT: No tv-out on this board, but who needs it when you've got a flat panel controller? It's probably available as an option if you call them.
                  just a thought
                  Any specific reason you wouldn't use an FV-24? They support up to 1.2ghz Pentium i believe. Plus it's got a PCI, onboard vid, sound, lan, firewire etc.
                  There's probably some obvious reason I'm missing.
                  HomePage and Mp3Car Setup
                    Re: just a thought
                    yeah...i want to see how small i can make the box...
                    abcd-1
                      No flat-panel controller.
                        yes..that mb look like the same one emacs offer but with tv out... let me call advantech
                        abcd-1
                          You might also want to call these guys:
                          http://www.icpamerica.com/magic_765.php
                          someone posted they have a good price if you call them!
                            But if you really want small, get a quote on this one:
                            http://www.icpamerica.com/wafer_7850.php
                            It is 140 x 102mm (Approx 6 x 4")and you can get a tv out
                              omg...keep it comming
                              Good thing i posted today
                              just called them on that mb..wafer-7850... $332
                              i think i will order this one
                              someone please change my mind
                              abcd-1
