long ide cable
  • long ide cable
    im thinking of putting my pc in my boot but want my dvd drive in the front
    does anyone now where i can get a long ide cable from? longest i have found on the net is 45cm's
    since im in the uk a uk based company would be best
    thanks
    IDE cables won't go that far. Put the DVD drive in an enclosure with a USB to IDE adapter.
    System status: in progress
      so i need to use a ide to usb at the fornt of the car then usb to ide at the rear?
        ide cables CANT really go anymore than about 45cm, any more than that and theirs signal loss, and your hd or cd drive or whatever more than likely wont run that well (if at all), some people have had success making their own cable a little bit longer, but, its not worth the effort, imo
        do what change said, put the dvd in an external enclosure, such as the one in the mp3car store, then just run the usb cable over 20 feet if you want to, another good thing about usb, the cable is smaller, so its easier to hide
          the enclosure is the usb->ide (the dvd drive slides into the enclosure)
          and at the mobo end, it has a male usb connector that just plugs straight into the mobo
            so i plug the drive into the encolsure at the front then just run a usb to the rear?
            that makes it alot aswell as the cable is smaller like you said
              exactly, the enclosure has a usb cable connected to it, with male on one end, and the enclosure on the other
              the dvd (we're talking about a slim-line dvd by the way), slides into the enclosure, then ur done that part, then the male connector into the mobo, and ur done, the pc should recognize it (drivers MIGHT be needed, depends on ur setup i guess)
              but its as simple as that
              1. put dvd into enclosure
              2. plug male end of usb into mobo
              3. profit
                um wtf? IDE cables get much longer then 45 cm, thats only 17 inches
                http://svc.com/rc36hd2.html they got 91 cm ides
                but yeah.......longer then that wont work, you need a usb convertor
                PC Components:
                My work log
                  personally i wouldnt use IDE for something like this
                  shorter ide cables work better
                  and in a car, usb is just so much easier
                  edit: reading into it, most suggest that 18" is the longest that can be reliably used, even then, the shorter the cable the faster it'll be
                  36" may in fact work, but, it'll be slower than an 18"
                  this taken from some webpage that i forget to get the URL for
                  There's a problem with any cable in which signals are transmitted in parallel format. Impedance varies in relation to frequency, and the longer the cable, the greater the chance of problems. When you split a byte into individual bits, and transmit the bits on separate lines, you can find that the rate of change of signal on each separate line (i.e. the frequency) varies according to the data you are sending, and therefore how often the state of each line changes. In extreme cases, this can mean that a bit from, say byte 100, might be delayed so long that it arrives at the same time as the rest of the bits from byte 101. Result - data corruption.
                    well you didn't search did u!
                    i tried this a few years ago and it crapped out. i even wrapped tin foil around it. then it worked a little. just get an external ide box and run it that way. i am doing it with a dvd drive and it works perfect. oh if you are trying to use a dvd, a long ide wont work for movies but its fine for music
                    99.9% complete.
                    http://www.cardomain.com/ride/212327
                      Same freaking question every month!! did you either bother to search? you know putting the word "long IDE cable" or "dvd in the front" or "IDE to USB"..!!!!
                      Thanatos.
                      RexBruMet Skin for FrodoPlayer
                      Nissan Aux-in MOD
                      Originally posted by bgoodman
                      We're an international forum, post in whatever langauge you like.
                        yeah thats funny cuz everybody starts out trying to get a long ide cable like they just thought it up lol
                        99.9% complete.
                          3. profit
                          You forgot a step. It's more like:
                          3. ???
                          4. profit
                          Gen 1: Pentium 3 1GHz - ATX - 2005
                          Gen 2: Pentium M 1.6GHz - ITX - 2006
                          Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
                          Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
                          ...it never ends
                            ahahahah, yeah, i forgot the question marks
                              Thanatos.
                              obviously i didnt search or i wouldnt be asking would i?
