Mini-ITX boards
This is a sticky topic.
  • Mini-ITX boards
    ok guys - because I'm getting extremely busy, and because this list is growing out of control for one person to maintain, I've started a WIKI page for it: http://www.mp3car.com/wiki/index.php/Mini-itx
    Yes, it still needs to be formatted. If someone wants to take it on, GO FOR IT! Remember, the wiki here is built by the users...so don't be shy.
    Everything you can put in there will help someone.
    So please! Have at it!
    __________________________________________________ _______________________________
    I figured a thread like this would be useful for a lot of people. What with all of the new mini-itx boards becoming available out there now, it's nice to be able to see them all at one stop.
    I'd like this thread to be kept free of any reviews, save those for the review forum please!
    In my searching I've just found this link: Linky!
    It's quite informative!
    So here goes!
    P4 boards
    Commell LV-670
    Socket 478 Intel Pentium 4 / Celeron @ 533/400 MHz FSB
    Intel Hyper-Threading Technology
    Intel Embedded 845GV/ICH4 Chipset
    Intel 845GV Built-in Extreme Graphics
    Intel Dynamic Video Memory up to 64MB
    Optional Single/Dual 18-/24-bit LVDS
    Onboard Intel PRO/100+ LAN
    5.1 Channel & S/P DIF AC97 3D Audio
    Onboard IEEE 1394 Interface
    Hi-Speed USB 2.0 with 480 Mbps
    AV/S-Video TV-out Interface
    IDE-based DiskOnModule SSD Interface
    Compact Size @ 170 x 170 mm (L x W)
    Commell LV-670M
    Mobile Intel Pentium 4 / Celeron CPU
    Intel Micro-FCPGA Package, 400 MHz FSB
    1 GBytes DDR266/333 SDRAM
    Intel NetBurst Microarchitecture
    845GV GMCH Built-in Extreme Graphics
    Single/Dual 18-/24-bit LVDS Interface
    Onboard PCI IEEE 1394 Interface
    i-Base MB877
    PDF Link
    Intel® Pentium 4, ATI RS400 Mini ITX Motherboard
    Mini ITX (170mm X 170mm)
    ATI RS400 Chipset, 400/533/800MHz FSB
    Supports Intel® Pentium® 4, up to 3.8GHz
    Built-in VGA, ATi M10 graphic core, support CRT or TV-out
    PCI Express Gigabit LAN controller
    Two DDR2 sockets support up to 2GB
    Digital I/O, Serial ATA, one PCI slot, AC97
    Four USB ports, four COM ports
    i-Base MB870
    PDF Link
    Intel® Pentium 4, ATI RS300M Mini ITX Motherboard
    Intel® Pentium® 4, 2.0GHz~3.2GHz
    ATI RS300M Chipset, up to 800MHz FSB
    Built-in VGA, AGP 4X, support CRT, TV-out & LVDS
    Realtek 8100BL 10/100Mb LAN controller
    One DDR socket supports up to 1GB Memory
    i-Base MB850
    PDF Link
    Intel 845 chipset with Pentium 4 processor-based 845GV mini-itx motherboard
    Intel® Pentium® 4 processor, 1.7GHz~3.06GHz
    Intel® 82845GV built-in VGA, AGP 4X, support CRT
    Optional Chrontel CH7017 LVDS supports LCD panel or TV Out
    Digital I/O (4 in/4 out), one PCI slot, AC97, four USB ports, four COM ports
    Jan Bennett
    Pentium Mobile / Celeron boards
    Commell LV-675
    Pentium M/Celeron M socket 479: 400/533 MHz FSB up to 2.26 GHz
    Chipset Intel 845G north bridge; ICH4 south bridge
    System Memory 1 DDR333/266 SDRAM sockets; Up to 1 GB memory size
    VGA built-in Intel Extreme Graphics
    Expansion Slots: 1 PCI; 2 Mini-PCI; Onboard IDE 1 Enhanced IDE (40 pin); 1 Ultra ATA 100 (44 pin); Onboard USB 4 USB 2.0; Onboard LAN Intel 82541PI Gb;
    Onboard Audio: Realtek ALC665 AC'97 Codec
    Onboard 1394 IEEE 1394 Firewire
    Back Panel I/O: 1 x VGA; 1 x LAN; 2 x USB 2.0; 1 x Parallel port; line-out, line-in and mic-in; 1 SPDIF Optical audio; 1 x PS2 mouse & keyboard; 1 IEEE 1394 Firewire
    Onboard I/O Connectors: 2 IDE (40 pin & 44 pin); 2 Serial; 1 Slim FDD; 1 USB 2.0; 1 GPIO connector; 1 SPDIF connector; 1 CD audio input; 1 IRDA
    Commell LV-673
    Intel Pentium M processor with Intel 915GM & ICH6M
    dual channel DDR2 400/ 533 MHz SDRAM up to 2GB
    Intel GMA 900 technology
    Intel 915GM integrated
    18-bit LVDS and analog TV-out interface
    Onboard PCI-Express 16x and Mini-PCI socket
    Support CompactFlash and PCMCIA on solder side
    6 x USB2.0 , 2 x RS232 , 2 x SATA, 1 x SPDIF , 1 x IrDA , 1 x GPIO
    Commell LV-671
    Intel® Centrino™ Mobile Platform
    Intel® Pentium® M Processor
    On-die 1 MB L2 Cache, 400 MHz FSB
    1 GBytes DDR266/333 SDRAM / ECC
    Intel Extreme Graphics 2 Technology
    Multiple Display LVDS / DVI / HDTV
    Intel PRO/1000 GbE Interface
    Intel PRO/Wireless WLAN 802.11a/b
    Mini-PCI, PCMCIA PC Card Interface
    IDE-based CompactFlash Interface
    i-Base MB879
    PDF Link
    Intel® Pentium® M, ATI Radeon Express Mini ITX Motherboard
    ATI Radeo Express 200 (RC410MD) Chipset,
    Supports Intel® Pentium® M/ Celeron® M, up to 2.26GHz
    Built-in VGA, ATi M10 graphic core, support CRT, TV out and LVDS
    10/100 LAN and PCI Express Gigabit LAN controller
    DDR2 socket support up to 1GB memory
    Digital I/O, Serial ATA, 1394, one PCI slot
    Six USB ports, four COM ports
    i-Base MB890
    PDF Link
    Intel 855GME Pentium M mini-itx motherboard
    Mini- ITX Form Factor (170mm X 170mm)
    Intel® 855GME or 852GM Chipset
    Supports Pentium® M / Celeron® M processors
    Up to 2.0GHz, 400MHz FSB
    1x DR DIMM, max. 1GB
    Integrated VGA, shared memory, CRT/LVDS/DVI
    Integrated 10/100 BaseT Ethernet
    Watchdog timer, 6x USB 2.0 ports, PCI slot
    Mini-PCI slot, optional 2x 1394
    i-Base MB896
    PDF Link
    Socket 479 Pentium® M Mini-ITX Motherboard with Intel® 915GM Chipset
    Supports up to 2.26GHz, 400MHz/533MHz FSB
    One DDR2 SDRAM DIMM, Max. 1GB memory
    Onboard 10/100 BaseT and Marvell PCI-Express Gigabit LAN
    Intel® 915GM VGA for CRT / 18-bit dual channel LVDS
    2x SATA, 6x USB 2.0, 2x COM, Watchdog timer, 1394
    1x PCI, 1x MiniPCI, 1xPCI-E(x1) slots, optional single/dual DVI card
    AOpen i915GMt
    Intel Pentium M CPU (Dothan) Socket 479 533MHz
    Chhipset: Intel 915GM Intel ICH6-M
    Main Memory: Realtek (RTM865) Dual Channel Mode Support : DDRII 667/533/400 DDRII DIMM x 2 DIMM Type : 128/256/512MB & 1GB Max Memory : 2GB
    Graphics: Integrated VGA Engine in chipset
    IDE: Integrated ATA100 and Serial ATA Controller
    LAN: Realtek Gigabit PCI LAN Chip
    Sound: Azalia 7.1 channel codec on-board (ALC880) Integrated in chipset
    Slots: PCI x 1
    Storage & Back Pannel I/O: Adapter Connector x 1, IDE Channel : ATA100 x 1, Serial ATA Channel x 2, PS/2, Keyboard x 1, PS/2 Mouse x 1, DVI Connector x 1, VGA Port x 1, Standard Video x 1, 1394 Port x 1, LAN Port x 1, USB Port x 4, COM Port x 1, Line_In x 1, MC_In x 1, Speaker_Out x 1, Center/Subwoofer x 1, Rear Surround x 1, Side Surround x 1
    On Board Connector: 4-pin 12V Connector x 1, CPU FAN x 1, System FAN x 1, Power Temperature Connector x 1, Front Panel x 1, USB Port x 4, COM Port x 1, IEEE 1394 x 1, S/PDIF x 1, CD_IN x 1
    BIOS: Award PnP 4Mb Flash ROM BIOS
    Form Factor: Flex ATX (mini ITX): 170 mm x 170 mm
    PSU: Carnetix p1900
    iGoLogic Inc MBI3368G
    Processor - Compatible with Intel® Pentium M and Celeron-M LV (Low Voltage) /ULV (Ultra Low Voltage) CPU’s
    Chipset - Intel® 852GM + ICH*4
    System Memory - 1 x 184-pin DDR DIMM memory up to 1GB
    VGA - Integrated in Intel® 852GM GMCH, max. up to 64MB frame buffer sharing system memory
    Expansion Slots - 1 PCI
    Onboard IDE - 2 x PATA-100 IDE
    Onboard LAN - Dual LAN (One Gigabit & One Fast)
    Onboard Audio - AC’97 codec audio
    Onboard LVDS Out - 2 x LVDS display out
    Back Panel I/O - 1 PS2 mouse port - 1 PS2 keyboard port - 2 RJ-45 LAN port - 3 Serial port - 4 USB 2.0 ports - 1 VGA port - 3 Audio jacks: line-out, line-in and mic-in
    Onboard I/O Connectors - 1 USB connector for 2 additional USB 2.0 ports - 1 COM port - 1 Front-panel audio connector (Mic-in and Line-out) - 1 FIR connector - 2 Fan connectors: CPU/Sys FAN - 2 LVDS connectors - ATX power connector
    Jan Bennett
      Core Duo and Core 2 Duo boards
      Kontron 986LCD-M/mITX
      Intel® Core™ Duo and Core™ Solo Processors (mPGA478 socket, mBGA479 prepared), Support Yonah and Merom CPU core, Front Side Bus 533/667 MHz, Intel® 945GM + Intel® ICH7R Chipset, Intel® GMA950 graphic controller on board
      Flat Panel Display Support, Dual independent Display Support (incl. 2x LCD)
      1x 16x PCI-Express /SDVO external graphic card socket
      2GB DDR2 memory support
      3x 10/100/1000 Mbps Ethernet
      8x USB 2.0, 4x RS232C, 2x IEEE1394, 1x ATA100 and 4x SATA150/300 IDE Controller, 1x Compact Flash socket, 1x mini PCI-Express socket for easy expansion of i.e. wireless LAN
      On board RAID 0/1/5/10 support with SATA harddisk
      7.1ch HDA / AC-97compliant audio output
      Size: 170 x 170 mm (6.7" x 6.7")
      i-Base MB899
      PDF Link
      Socket 478 Intel® Core® Duo Mini-ITX Motherboard
      Socket 478 for Intel® Core™ Duo /Solo processors
      Mobile Intel®; 945GM Chipset, Two DDR2 DIMM sockets
      Supports CRT, LVDS, optional TV out or DVI
      10/100 BaseT LAN, PCI Express Gigabit LAN
      SATA x2, USB x6, Digital I/O, Watchdog timer
      PCI x1, PCI-E (x1) x1, Mini PCI x1, Mini PCIe x1
      AOpen i945GTt
      INTEL Core Duo i945GTt
      CPU: Intel Core Duo/Core Solo CPU (Yonah)
      Chipset: Intel 945GT Intel ICH7MDH
      Main Memory: Dual Channel Mode Support : SO-DIMM DDRII 667/533/400, SO-DIMM DDRII 667/533/400 x 2, 128/256/512MB & 1GB x 2, Max Memory : 2GB
      LAN: Intel Gigabit PCI Express LAN chip
      Sound: Azalia 7.1 channel codec on-board (ALC882D)
      Slots: PCI Express (PCIe x1) x 1, Mini PCI x 1
      Storage & Back Panel I/O: Adapter Connector x 1, IDE Channel : ATA100 x 1, Serial ATA Channel x 2, PS/2 Keyboard x 1, PS/2 Mouse x 1, DVI Connector x 1, Standard Video x 1, 1394 Port x 1, LAN Port x 1, USB Port x 4, COM Port x 1, Line_In x 1, MIC_In x 1, Speaker_Out x 1, Center/Subwoofer x 1, Rear Surround x 1, Side Surround x 1
      On Board Connector: 4-pin 12V Connector x 1, CPU FAN x 1, System FAN x 1, Front Panel x 1, USB Port x 2, COM Port x 1, COM2 x 1, IEEE 1394 x 1, S/PDIF x 1, CD_IN x 1
      BIOS:Award PnP 4Mb Flash ROM BIOS
      Commell LV-677
      CPU: Intel Core Duo and Intel Core Solo processors @ 667MHz FSB.
      Memory: 2 x 240 pin DDR2 533/667MHz up to 4.0GB.
      Chipset: Intel 945GM and ICH7-M.
      VGA Interface: Intel 945GM integrated GMA 950 Technology.
      LVDS Interface: 18-bit dual channel LVDS interface.Supports up to WUXGA panel resolution.
      TV out: HDTV built-in.
      LAN Interface: Intel 82537L PCIE Giga LAN
      PCI Enhanced IDE: UltraATA100 IDE up to 2 ATAPI .
      Serial ATA: Integrated Serial ATA controller facilitates high-speed data transfers at up to 150 MB/s for each of 2 ports.
      Audio: Intel ICH7-M integrated with Realtek ALC880 High Definition Audio.
      I/O Ports:1 x RS232 and 1 x RS232/422/485 Serial Ports, 1 x Parallel port, 6 x USB2.0 ports, 1 x DB15 VGA port, 1 x IEEE1394, 1 x PS/2 keyboard and mouse ports.
      Extended Interface: One PCI Express x 16 bus add-in card connector, 2 x Mini-PCI socket
      SSD: IDE1 supports DOM, 1 x CompactFlash socket (underneath board)
      GPIO Interface: Onboard programmable 8-bit Digital I/O interface.
      Power supply: ATX P/S or DC 8~21V used optional.
      Power requirements : Most core duo use a max of 31watts, and the DC board version has built in regulator so you only need a uSDC20A from mpegbox and you will get ypur 12V/5A + 5V/3A onboard regulated for devices such as hd's and usb hubs. The onboard regulator also survives engine cranking and ranges from 8 to 21 Vdc
      Endura TP945GM
      Intel® Core™ Duo, Celeron® M, LV and ULV processors; Intel® 945GM Express chipset; 667/533MHz Front-Side Bus
      Two DIMM sockets; Up to 4GB DDR2-667 memory; Dual-Channel memory
      Intel® GMA950 Graphics; x16 PCI Express graphics slot; 18-bit, dual channel LVDS; TV-out header; VGA output; Dual independent displays
      Intel® High Definition Audio; Eight channel CODEC for 7.1 audio; S/PDIF digital audio output
      Mini-PCI Type lllA socket; PCMCIA Type II socket; Compact Flash Type I socket
      Single or dual Gigabit Ethernet; Eight USB 2.0 ports; Four RS-232 serial ports
      PS/2 keyboard and mouse ports; IrDA interface
      Two SATA 1.5 Gbps ports; One Ultra ATA100 port
      TPM 1.2 header
      GPIO port
      ACPI 3.0
      BCM MX945GM
      CPU Intel® Core™ Solo/Duo, Core™ 2 Duo/ Celeron M (65nm) Socket M; 533/667MHz FSB; Core Logic Chipsets Intel® Mobile 82945GM GMCH; Intel® 82801GM ICH7M
      System Memory 1 x 240-pin DIMM socket support up to 1GB Dual Channel DDR2 533/667MHz SDRAM
      Expansion Interface 1 x PCI Express x16; 1 x PCI slot (PCI Rev. 2.2 compliant)
      Onboard I/O: PS/2; 1 x K/B, 1 x Mouse; IDE 1 x EIDE (Ultra DMA 100); USB 4 x USB 2.0 ports; SATA 2 x SATA; Parallel Port 1x LPT; Serial Port 2 x RS485, 3 x RS232; DI/O 16-bit General Purpose I/O for DI and DO
      Intel® 82945GM GMCH Integrated Graphics Media Accelerator 950; Display Memory Intel® DVMT 3.0 supports 224 MB video memory; Resolution 2048 x 1536 @ 32 bpp (85 Hz); Dual Display CRT + LVDS; VGA Interface 1 x DB-15 VGA Connector
      LVDS Single Channel 18-bit/Dual Channel 36-bit LVDS
      AC'97 Codec Realtek® ALC888 support 7.1 CH HD Audio; Audio Interface Mic-In, Line-In, Line-Out, SPDIF
      Power Supply Voltage: +5 V @ 3.34 A, +12 V @ 0.09 A, +3.3 V @ 3.74 A, 5 Vsb @ 0.23 A (with Intel® Pentium® M 1.8 GHz & 256 MB DDR SDRAM)
      AMD mobile boards
      Jetway J7F3 Series
      PDF Link
      SiS 741CX Northbridge + SiS 964 Southbridge Chipsets
      Support Socket-462 AMD Geode NX processor
      Support Front Side Bus 133MHz
      Single Channel DDR2 400 Memory DIMM
      Support 2 Serial ATA Devices with RAID 0, 1
      Support 2xAD Connector With Expansion Daughter-boards
      Ethernet LAN Supported
      AC’97 6 Channel Audio CODEC
      VIA VT6307S IEEE1394a Controller for J7F3E
      17 x 17CM Mini-ITX Form Factor
      i-Base MB740
      PDF File
      AMD Geode NX Mini ITX Motherboard
      Socket A for AMD Geode NX processors
      Up to 1.4GHz speed, 133MHz FSB
      DDR DIMM x 1, Max. 1GB, DDR266/333
      Onboard 10/100 and Realtek 8110S Gigabit Ethernet
      Integrated SiS 741CX VGA, supports CRT
      Optional LVDS/TV-out, DVI/CRT2 MAGP VGA cards
      2 x SATA, 6 x USB 2.0, 2 x COM, Watchdog timer
      1x PCI, 1x Mini PCI, 1x MicroAGP, optional 1394
      Albatron KI51PV-754
      AMD Athlon™ 64 / Sempron™ /Turion™ 64 Processors
      Socket 754 with Hyper Transport?800+ MHz
      1 DDR333/400 Memory Sockets
      Integrated NVIIDA GeForce 6150 Graphics Engine.
      Provides DVI / D-SUB / HDTV-out (by optional cable) interface.
      Realtek AC97 6 channel
      Marvell 10/100 Mbps LAN PHY / Marvell Gbit LAN & NVIDIA Active Armor
      1*PCI Solt
      4 SATA II Channels, SATA RAID 0,1,5& 0+1
      2 ATA133 Channels
      Dual BIOS (Second BIOS by Optional ABS Card)
      8 USB 2.0/1.1 Ports (4 ports by optional cable)
      Jan Bennett
        VIA boards
        VIA EPIA CN13000
        1.3GHz/1.0GHz VIA C7 nanoBGA2 Processor; CN700 North Bridge; VT8237R-Series South Bridge
        1 DDR2 400/533 DIMM socket, Up to 1GB memory size
        Integrated VIA UniChrome™ Pro AGP graphics with MPEG-2 decoding acceleration
        1 PCI
        UltraDMA 133/100/66 Connectors
        VIA VT1618 8-channel AC'97 Codec
        Back Panel I/O: 1 PS2 mouse; 1 PS2 keyboard; 1 Serial; 1 VGA; 1 RJ45; 4 USB 2.0; 1 RCA (S/PDIF or TV out); 1 S-Video; 3 Audio jacks: line-out, line-in and mic-in (Horizontal, Smart 5.1 Support)
        Onboard I/O Connectors - 1 USB connector for 4 additional USB 2.0; 2 SATA; 1 Front-panel audio (Mic and Line Out); 1 CIR (Switchable for KB/MS); 1 LPT; 1 CD-in; 2 Fan: CPU/Sys FAN
        VIA EPIA EN15000
        1.5GHz/1.2GHz VIA C7 nanoBGA2 Processor; CN700 North Bridge; VT8237R-Series South Bridge
        1 PCI
        2 UltraDMA 133/100/66 Connectors
        VIA VT1618 8 channel AC'97 Codec
        VIA VT6307S IEEE 1394 Firewire
        Back Panel I/O - 1 PS2 mouse; 1 PS2 keyboard; 1 Serial; 1 VGA; 1 RJ45; 4 USB 2.0; 1 RCA (S/PDIF or TV out); 1 S-Video; 3 Audio jacks: line-out, line-in and mic-in (Horizontal, Smart 5.1 Support)
        Onboard I/O Connectors - 1 USB connector for 2 additional USB 2.0; 1 1394 connector for 1 1394; 2 SATA; 1 LPC; 1 Front-panel audio (Mic and Line Out); 1 Serial port connector for a second com; 1 CIR (Switchable for KB/MS); 1 SIR pin header (IrDA 1.0); 2 Fan: CPU/Sys FAN; 1 SMBUS; 1 S/PDIF in; 1 S/PDIF out; 1 LVDS/TTL/DVI module (an add-on card is required); 1 Component (YPbPr) video pin header
        VIA EPIA SP13000 and SP8000
        VIA C3™/ VIA Eden™ EBGA processor; CN400 North Bridge; VT8237R-Series South Bridge
        1 DDR266/333/400 DIMM socket. Up to 1GB memory size
        Integrated VIA UniChrome™ Pro AGP graphics with MPEG-2 decoder /MPEG-4 Accelerator
        1 PCI
        2 X UltraDMA 133/100 Connector; 2 SATA Connectors
        VIA VT1617A 6channel AC'97 codec
        Back Panel I/O - 1 PS2 mouse; 1 PS2 keyboard; 1 RJ-45 LAN; 1 Serial; 2 USB 2.0; 1 VGA; 1 PCA (SPDIF or TV out); 1 S-video; 3 Audio jacks: line-out, line-in and mic-in (Smart 5.1 Support)
        Onboard I/O Connectors - 3 USB connector for 6 additional USB 2.0; 1 1394 connector for 1 1394; 1 Serial port connector for a second com; 1 VIP; 1 Front-panel audio (Mic-in and Line-out); 1 CD audio-in; 1 FIR; 1 CIR (Switchable for KB/MS); 1 LPT port ; 1 Wake-on-LAN; 2 Fan: CPU/Sys FAN; 1 I2C; 1 LVDS/TTL module (Optional); 1 +12V power
        VIA EPIA ML6000 and ML8000
        VIA C3™/ VIA Eden™ EBGA processor; CLE266 North Bridge; VT8235M South Bridge
        1 DDR266 DIMM socket, Up to 1GB memory size
        Integrated VIA UniChrome AGP Graphics with MPEG-2 Accelerator
        1 PCI
        2 X UltraDMA 133/100/66 Connectors
        VIA VT1616 6 channel AC' 97 codec
        Back Panel I/O - 1 PS2 mouse; 1 PS2 keyboard; 1 Parallel; 1 RJ-45 LAN; 1 Serial; 2 USB 2.0; 1 VGA; 3 Audio jacks: line-out, line-in and mic-in (Smart 5.1 Support)
        VIA EPIA MII12000 and MII10000 and MII6000
        Integrated VIA Unichrome AGP graphics w/MPEG-2 Accelerator
        1 PCI
        2 X UltraDMA 133/100/66 Connector; 1 x FDD Connector
        VIA VT6103 10/100 Base-T Ethernet PHY
        VIA VT6307S IEEE 1394 (Optional)
        Onboard CardBus / CompactFlash - CardBus Type I & Type II; Ricoh R5C476 II / R5C485 CardBus Corntroller
        Back Panel I/O - 1 CardBus Type I and Type II slot +1 CompactFlash; 1 CompactFlash; 1RJ-45 LAN; 1 PS2 mouse; 1 PS2 keyboard; 1 Serial; 2 USB 2.0; 1 VGA; 1 RCA (SPDIF or TV-Out); 1 S-Video; 1 1394; 3 Audio jacks: line-out, line-in and mic-in (Smart 5.1 Support)
        Onboard I/O Connectors - 1 USB connector for 2 additional USB 2.0; 1 Front-panel audio (mic-in and line-out); 1 CD Audio-in; 1 FIR; 1 CIR (Switchable for KB/MS); 1 Wake-on-LAN; 1 LPT port; CPU/Sys FAN/Fan 3; 1 Connector for LVDS module (Optional); 1 Serial port connector for second COM port
        VIA EPIA M10000 and ME6000
        Integrated VIA Unichrome AGP graphics with MPEG-2 Accelerator
        1 PCI
        VIA VT1616 6 channel AC'97 Codec
        Back Panel I/O - 1 PS2 mouse; 1 PS2 keyboard; 1 Parallel; 1 RJ-45 LAN; 1 Serial; 2 USB 2.0; 1 VGA; 1 RCA (SPDIF or TV out); 1 S-Video; 3 Audio jacks: line-out, line-in and mic-in; can be switched to 6 channel output
        Onboard I/O Connectors - 1 USB connector for 2 additional USB 2.0; 2 1394 connectors for 2 1394; 1 Front-panel audio connector (Mic and Line Out); 1 CD Audio-in; 1 FIR; 1 CIR (Switchable for KB/MS); 1 Wake-on-LAN; CPU/Sys FAN/Fan 3; 1 SMBUS; 1 Connector for LVDS module; 1 Serial port connector for a second com port
        VIA EPIA 800 and 5000
        VIA C3/EDEN EBGA Processor; PLE133 North Bridge; VT8231 South Bridge
        2 PC133 DIMM sock, Up to 1 GB memory size
        Integrated AGP 4X Graphics
        1 PCI
        VIA VT1612A 2 channel AC'97 Codec
        Back Panel I/O - 1 PS2 mouse, 1 PS2 keyboard, 1 VGA, 1 Parallel, 1 RJ-45 LAN, 1 RCA (SPDIF or TV out), 1 S-Video, 2 USB 1.1, 1 Serial, 3 Audio jacks: line-out, line-in and mic-in
        Onboard I/O Connectors - 1 USB connector for 2 USB 1.1, 1 CD Audio-in, 1 FIR, 1 CIR, 1 PS2, 1 CPU/Sys FAN
        Jetway 627F Series
        PDF Link
        Support VIA C3 processor in EBGA packaging, for 133MHz Front Side Bus Frequency; VT8623 North Bridge; VT8235 High Bandwidth Vlink Client South Bridge
        1 x 184-pin DDR Module Sockets Support Max 1GB, 2.5V DDR266 DDR SDRAM
        Support 2 x Ultra DMA 133 IDE Interface
        128bit 2D/3D graphics engine
        Support NTSC/PAL TV system S-Video/AV Output
        6xUSB 2.0, 1xParallel
        Jetway / Phylon / Versa / Vista J7F2WE
        PDF Link
        VIA CN700 Northbridge + VT8237RP Southbridge Chipsets (MCP51G); VIA C7 Nano-BGA processor
        CPU core speed
        1G0 is 1.0GHz C7 CPU [All]
        1G2 is 1.2GHz C7 CPU [Jetway Only]
        1G3 is 1.3GHz C7 CPU [Phylon Only]
        1G5 is 1.5GHz C7 CPU [All]
        VIA VT6307S IEEE1394a Controller for J7F2E / J7F2WE
        Jetway J7F4 Series
        PDF Link
        VIA VT1622A TV encoder
        VIA EPIA VB6002
        VIA VN800 North Bridge; VT8237R series South Bridge
        1 DDR2 533 DIMM socket; Up to 1GB memory size
        Integrated VIA UniChromeTM Pro AGP graphics with MPEG-2 decoding acceleration
        1 PCI
        VIA VT1618 AC'97 Codec with 6-channel support
        Onboard I/O Connectors: 2 USB pin connectors for 4 additional USB 2.0; 2 SATA; 1 LPC; 1 LPT; 1 Digital I/O (4GPI/4GPO); 1 Front-panel audio (Mic In and Line Out); 1 COM (with Vcc 5V/12V Support); 1 CIR (Switchable for KB/MS); 1 SIR; 1 S/PDIF out; 2 Fan (CPU/Sys FAN); 1 SMBUS; 1 LVDS/ DVI module (an add-on card is required); ATX Power
        Back Panel I/O: 1 PS2 mouse; 1 PS2 keyboard; 1 Serial; 1 VGA; 2 RJ-45 LAN; 4 USB 2.0; 3 Audio jacks: line-out, line-in and mic-in (Horizontal, Smart 5.1 Support)
        Jan Bennett
          aopen i945GTt
          any serious list of mini-atx mobos has to include one for the intel core 2duo merom. The i945GTt is such a mobo, and this site already contains info from potiential users.
          INTEL Core 2 Duo i945GTt
          CPU
          Intel Core Duo/Core Solo CPU (Yonah), or Core 2 Duo CPU (Merom)
          Socket 479
          667MHz
          Chipset
          Intel 945GT
          Intel ICH7MDH
          Super I/O
          Winbond (W83627EHF)
          Clock Gen.
          ICS
          Main Memory
          Dual Channel Mode
          Max Memory : 2GB
          Graphics
          IDE
          Max Disk : 144,000,000GB [by 48 bits LBA Spec.]
          LAN
          Sound
          USB
          USB2.0 x 8
          IEEE 1394
          Agere 1394 Control Chip (FW3226-100)
          Slots
          Mini PCI x 1
          PS/2 Keyboard x 1
          PS/2 Mouse x 1
          DVI Connector x 1
          Standard Video x 1
          1394 Port x 1
          LAN Port x 1
          USB Port x 4
          COM Port x 1
          Line_In x 1
          MIC_In x 1
          Speaker_Out x 1
          Rear Surround x 1
          Side Surround x 1
          On Board Connector
          CPU FAN x 1
          System FAN x 1
          Front Panel x 1
          USB Port x 2
          COM Port x 1
          COM2 x 1
          IEEE 1394 x 1
          S/PDIF x 1
          CD_IN x 1
          BIOS
          Form Factor
          Flex ATX (mini ITX)
            Just a suggestion, but I think we should try to add at the bottom of each board description if it supports 800x480 that would save alot of questions.
              good idea, if possible can you add the compatible PowerSource, Ex. Carnetix, Opus
              [M10K][TinyXP][Roadrunner Frontend][OEM Enclosure]
              [iGmon]
              Download MP3 MixTapes
                if you know of a way to find this out, let me know!
                Jan Bennett
                  this is highly dependant on the perpherials and the processor specs that you are running.
                  Jan Bennett
                    Aopen i915GMt-FSA
                    Socket 479 533MHz
                    Intel 915GM
                    Intel ICH6-M
                    Winbond (W83627THF)
                    Realtek (RTM865)
                    Dual Channel Mode
                    DDRII DIMM x 2
                    Max Memory : 2GB
                    USB2.0 x 8
                    PCI x 1
                    PS/2 Keyboard x 1
                    PS/2 Mouse x 1
                    DVI Connector x 1
                    VGA Port x 1
                    Standard Video x 1
                    1394 Port x 1
                    LAN Port x 1
                    USB Port x 4
                    COM Port x 1
                    Line_In x 1
                    MC_In x 1
                    Speaker_Out x 1
                    Rear Surround x 1
                    Side Surround x 1
                    CPU FAN x 1
                    System FAN x 1
                    Front Panel x 1
                    USB Port x 4
                    COM Port x 1
                    IEEE 1394 x 1
                    S/PDIF x 1
                    CD_IN x 1
                    Flex ATX (mini ITX)
                    170 mm x 170 mm
                    PSU Carnetix p1900
                      oldmadog and acuracl - both have been added - thanks for the input!
                      Jan Bennett
                        FYI, the Commell LV-671 is a Pentium M board, not P4.
                        The LV-673 is a PM board also which I currently use (successor to the LV-671).
                        Jarrod - Holden VX S!
                          moved the 671 and added the 673 - good eyes!
                          Jan Bennett
                            Commel LV677 (or LV677-DC)
                            I/O Ports:
                            1 x RS232 and
                            1 x Parallel port
                            6 x USB2.0 ports
                            1 x DB15 VGA port
                            1 x IEEE1394
                            Extended Interface:
                            2 x Mini-PCI socket.
                            Not doing carpc anymore
                              dopehead - added - thanks!
                              Jan Bennett
