KX Project Drivers?
  • KX Project Drivers?
    I saw these mentioned in another thread, here and went looking for more information on them.
    I found the website, located here and a review on Techspot, located here
    Has anyone used these, and if so, what are your opinions on them? My setup uses an Audigy 2 NX USB card, so these drivers are a no-go, according to their FAQ, but if they are that much better, I might bite the bullet and switch to a PCI card.
    Thanks for any info
    Dave
    2005 Infiniti G35 6MT Coupe Black/Black
    Core Duo CarPC
    CarDomain page
    i tired to use them but didnt get them to work. I was able to configure the audigy drivers to work quite well with some tweeking. what exactly are the stock drivers not doing for you?
    MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
    M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
    7" Lilliput 619 | WinTV | WIFI | Bluetooth
    Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
    Roadrunner | LSXvoid | IGuidance 3
    My Worklog
      Well, among other things, the drivers for the Audigy 2 NX don't allow true 4.1 sound. They have 5.1 and 4.0, but not no 4.1
      Really, though I am just looking for an alternative
      Dave
      Core Duo CarPC
      CarDomain page
        *First, scuse my english, not enought time to correct it right now...
        I im using them at home right now to test how i could use them in the car in the future (my car PC will be mostly for sound purpose...).
        What i can say is that you have alot more control on how the sound is processed before being play. What i really like, is that you can have more setting that you can find on a very very expensive Car Radio. I mean, lowpass, highpass, equalizer, time correction, gain, effect, wave generator etc etc etc.... You can had some or modify the existing if you want. You can set everything on each channel, even on what ouput you want it...
        **Dont be scare by the DSP, it is way easier than what it look like...
        Carputer Athlon X2 4200+
        800tsv - Audigy 2 ZS - PowerMate - Wifi 802.11n
        All Audio Tunning done via Software. 7 channels.
        CDT ES-07 - HD2 - DRT25
        ED Nine.2x
        ED Nine.4
        ED Nine.1
        ED 110v.2 (x2)
          no audigy has true 4.1 even though the option ios there for it. You just have to set it to 4.0 and split off the rear output for the sub. Thats what i did and its fine.,
          My Worklog
            Whit the KX driver, you can have the 4 channel + a subwoofer too...
            ED Nine.2x
            ED Nine.4
            ED Nine.1
            ED 110v.2 (x2)
